My Pond Project
/ My Pond Project #22
Great pictures. It's an amazing project that you are undertaking, especially with having to pump out the water so that you can get back to digging. I did just the oposite, in almost the same way. I bought a 3 inch trash pump and put an old fuel tank on top of it with a wood frame. Your metal frame and matching paint job on your tank looks very profesional. Much nicer then mine!!!
With all the dirt you are removing, can you just dig down 4 feet in areas before you do some serious digging to make sure you don't hit bedrock? If you do, you should be able to fill the hole and compact it without creating a leak. If you don't hit rock, you know that you are good to go for at least another two feet of depth. I'd always try to have at least two feet of good clay underneith you just in case the bedrock is just inches under your test hole.
Thanks for the update, it's a fun project for us to follow along,
Eddie
/ My Pond Project
What I plan to do Eddie, is in the yellow hatched area, dig down with my excavator 5 feet, level it off, and get a ramp down in it for my dump truck.
Then dig from that platform allowing me to get that section of the pond 4-5 feet deeper. If I hit bedrock while doing that I'll make sure to cover it back up with 2 ft of clay...
It's too late for me to get the other sections of the pond deeper. It will never be dry enough for me to get in there...
/ My Pond Project #24
As luck would have it, I was in the same situation with my pond, but then we had two years of drought. I joked with my wife that as soon as I finished digging it, the rains would return, and they did. It was the third wettest year in history!!!
Even if it doesn't dry up for you, it sure sounds like you have a good plan and I admire your determination. Maybe when you get that area dug out, the water will move there and you can dig in other areas.
Do you still need the dirt for your building pads? Or do you have enough and you're just digging for the depth?
Eddie
/ My Pond Project #26
ETD66SS said:
Hey, you should have similar fishing ponds in Michigan to what we have here in NY.
I fished a lot of ponds as a kid, and never did I catch any SMB. Always LMB, BG & Sunfish...
Have you fished ponds in your area with SMB? How big were the ponds, were they deep?
Yeah, there are lots of ponds/lakes around here with SMB. As ponds go they are easier to get to live with something else, ie walleye or bluegill. The only thing that stops a SMB or LMB from eating something is mouth size, obviously LMB has a much larger mouth so they can eat pretty much anything. I think it is a lot of personal preference. I grew up catching smallies and think they are a lot of fun, so that is my preference.
Lots of work, I wish I had the time or equipment to do the same.
/ My Pond Project
So I went to check on the pump progress, 4th day.
Took some pictures:
etd66ss's photos. Get free image hosting at ImageCave.com - free image hosting at ImageCave.com
I checked out the pump, then turned the idle down a bit because it's getting close to sucking the pond dry, I did not want it to run dry over night.
After that, I went over to the discharge hose where it lay in the ditch, and noticed a pile of bullfrog tad pole remains, so decided to take a picture of that:
http://usera.imagecave.com/bhaal/BG/Pump_0160.JPG
As I was taking that picture I noticed something in the water swim really fast past the lens, I knew it could not be a tad pole swimming that fast.
I saw two of these in the ditch, they made it through the trash pump:
I guess all my posted & no trespassing signs didn't keep the kids from throwing BG in my ponds...
I was only able to catch one of them and moved it to the smaller pond that I'm not currently pumping out.
/ My Pond Project #29
That's not a bluegill(BG)...its a green sunfish. They have a few characteristics that distinguish them from BG including an ability to survive in almost any water condition. They are also found almost everywhere. They have a mysterious ability to show up in water without any apparent human intervention. I've got a couple of wet weather creeks on my place and they always have greensunfish in them when they have water.
/ My Pond Project
I started work on the banks today.
I'm cutting down into the clay as far out as I can reach with my CAT 225. Then shape the banks with my D6C. I will then layer ~2' of clay down from where I hit the clay digging, all the way up to the rim of the basin.
I don't have a sheepsfoot roller, so hopefully driving on the clay with my dozer will pack it in place enough to avoid serious erosion if we get down pours.
I have lake laid clay, swells up a great deal when it gets wet, almost acts like betonite, so when it gets wet initially, it should hold to the banks pretty well I hope.
Here are some pics:
whitedwarf3's photos. Get free image hosting at ImageCave.com - free image hosting at ImageCave.com
/ My Pond Project #33
Looks good. This may be a non issue for you but will the pond be filled all the way near the top eventually? If so will the more gradual slope create an environment to promote a ton of plant growth? Just a thought as if that isn't what you are looking for you could adjust now. Looks great though.
/ My Pond Project
That slope is about all my dozer can handle back blading up the bank.
The pictures make it look shallower than it is. I will take a level and measure the slope, but by eye, looking at it in person, it looks like a 3:1 slope, 18 degrees. That is what was recommended to me by the county conservationist for safety & wildelife access. Some parts of the bank will end up steeper, and I'll have to spread out the clay with my excavator. I really have no way to pack it down however.
No, I don't want weeds all round the banks of my pond. However, any steeper and the dozer struggles to back up the bank.
I will measure it for sure to check.
The water level after I line with clay should theoretically be 1-1.5 ft below the basin.
I also wanted the tops of the bank shallow for mowing purposes.
/ My Pond Project #35
Cool, 3:1 sounds about right, for some reason it looked shallower to me. Nice work and whatever the slope it sure looks pretty.
/ My Pond Project
I don't know why my camera does that.
But it is something I want to check, as I hate cattails, etc...
Lemme just say it feels steep when pushing the clay down hill with he dozer!
/ My Pond Project #37
That mowing angle can be a tricky one. I thought mine was pretty shallow above the waterline and even drove over it with my small tractor to make sure it wasn't too steep. Then as the grass started to grow and the rains eroded part of it and the water level rose, my plan went right out the window. I can mow all around my pond, but there are places that I'm out of the seat as it's so steep and bouncy due to the ruts. Walking around it, the ruts look small. In fact, with the grass grown in, you can't see the ruts. But on the tractor mowing, you sure can feel them.
There is only so close to the water that I can get before sinking in. I cannot mow to the waters edge, it's just too soft for the weight of the tractor. What are you going to mow with and how close to the water do you want to mow? If I was to do it again, I would make my slope allot less. I still might with the dozer if the rains stop long enough and the water drops down to where I don't have to worry about getting stuck.
My neigbhor is digging a pond and his dam is done. He's still digging out the pond itself with a pipe through it for a drain. It might take him a few more years to get it dug this way, but he's trying to maintain his dam. His slope is too much for his tractor and he's doing it by hand with a weedeater. He might have to add a massive amount of dirt to get a slope that he can mow, but until then, he's struggling to keep it under control.
Eddie
/ My Pond Project
I want to be able to mow right up to the waters edge.
Here is a sketch of the planned bank cross-section:
/ My Pond Project
Well, I checked the slope, it's ony 4:1.
I tried to do a section of the bank at 3:1, but got my dozer spinning it's tracks in the loose soil, it could not make it up that incline. Good thing I had the excavator to pull it out.
Will I have vegetation problems with a 4:1?
/ My Pond Project #40
Only way to know for sure is to drive it with what you plan to mow it with. My dam is 3:1 under water and then works it's way to flay in 12 to 20 feet. It's pretty scary in places, but doable. I just have to go real slow. Having the finish mower has made a huge differenc in the slope that I can mow and in not getting stuck as easy. The rotary mower put allot of weight on the rear of the tractor and it sunk much faster!!!!
Honestly, if you plan on living there and maintaining it, get the mowing slope as shallow as possible. Spend the time now to get it right and enjoy it the rest of your life. Get it too steep and the rest of your life, this will always be an issue for you.
Eddie
Pull-Type Hay Stacker (A66408)
Pull-Type Hay...
6ft Metal Star (A65583)
6ft Metal Star...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2004 Chevrolet 2500HD (A66408)
2004 Chevrolet...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
