MY2012 5085M ordered today!
   / MY2012 5085M ordered today! #351
pclausen, any chance of posting a picture of your OEM top link holder?
Thanks for the compliment on the workmanship. ;)
There's a pretty good picture at post #291
Brian, here are some better pictures of both the OEM top link holder and the "handle" and how the handle is connected to the top link.
Are you thinking of fabricating and offering an add-on kit for this? ;)
   / MY2012 5085M ordered today! #354
Peter your hose routing looks 10 times better than the dealer did :thumbsup:
Brian might be able to weld a lug for the handle d1rectly to the cylinder, something I'd be afraid to do. My luck I'd distort the cylinder or melt something inside. Reason I was going to explore a clamp on option.
   / MY2012 5085M ordered today! #355
Clamp on option is probably the easiest and safest. I know that most of the time the OEM top link retainer can be modified in some way so that it can be used to hold a hydraulic top link. But as we all know, bungee cords are a lot easier and most people don't or can't do the modifications required to be able to make use of the OEM retainer. :(
pclausen, as far as the pictures, I just wanted to see what you had to work with. The clamp on bracket is probably going to be the easiest solution. ;)
Ok, thanks Brian. That's what I'll pursue then.
Btw, you were right, I should probably have opted for slightly longer hoses.
I'll see how this works out and if the 90's twist loose with this configuration or not.
   / MY2012 5085M ordered today! #357
pclausen, put the 90 at the tractor end at a 90 to the cylinder pointing to the right as it is, but 90* to the cylinder . Put the 90 at the rod end pointed straight back towards the tractor and put the hose back over to the left side. That should work out for you, if not, a couple of hoses would be pretty cheap. ;)
   / MY2012 5085M ordered today! #358
How long of hoses did you use? 24"? Also I see the toplink is resting on the PTO guard. I don't see the toplink ever being that low in actual use.
Might try a straight fitting at the head end of the cylinder and pointing the 90 towards the tractor, maybe at 1 o'clock.
   / MY2012 5085M ordered today! #359
It is best to have a loop of some kind. That relieves stress put on the fittings. I recommend 30" or 36" long hoses and to have the 90* fittings pointing back towards the implement. That gets you the loop in the hoses. ;)
   / MY2012 5085M ordered today! #360
I agree the 90s pointing towards the implement and longer hoses would be the best.
My first suggestion was to try and make better what he has.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
Sterling AT (A55301)
2020 Deere 325G (A50123)
2020 Deere 325G...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
FAKE (A52472)
FAKE (A52472)
