Mystery holes in MF230?
   / Mystery holes in MF230? #22
I wonder if there is similar one on other side maybe hidden by something, if so these could be for lifting adapters for engine itself.
I really don't think so ,As these tractors don't have a frame everything bolts to the engine , trans. , & differential ! & that was quite common on M-F utility tractors from this period on back , & my 59 M-F 50 is the same way with no frame or sub frame.
   / Mystery holes in MF230? #23
AH I did not know that. thought this was closer to the CUT style.
   / Mystery holes in MF230? #24
It could be for a motor mount on some other piece of equipment that used the same block.
   / Mystery holes in MF230? #25
Have a 240 with 152 perkins, I'll have to look, I think the grease fitting bank for the front pivot bolts there.
   / Mystery holes in MF230? #26
Probably front engine mounts, this engine is used all over for all kinds of application and it's the oil pan that carries the load from back to front if I remember correctly, nor the engine it self.
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
2014 FREIGHTLINER DAYCAB ROAD TRACTOR (A57192)
2014 FREIGHTLINER...
2023 Kubota L2502DT (A53317)
2023 Kubota...
2007 Anderson 25ft 7 Ton T/A Flatbed Equipment Trailer (A55852)
2007 Anderson 25ft...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
Kubota HB84 (A53317)
