N843 Spill timing test
   / N843 Spill timing test #1
Andrewpower101
Rangerpower!0!
Hi all! I recently re sealed the injection pump on my N843 and ever since I've had a ton of issues. I finally took the injection pump completely out of the tractor and went over it top to bottom and made sure it was perfectly in time as well, my only issue left is heavy black/grey smoke. I attempted to do a spill test to check the timing but it seems no matter the position on the crank shaft fuel shoots out of the number one injection port on the pump. I don't have an old tube to cut up so I'm kind of just making a mess as well, lol. I did not remove or add any shims to the pump since the rebuild but I assumed I wouldn't have to considering all the components are the same as before. one last thing is the tractor was running like a top before I re sealed the pump so in theory I shouldn't have any other problems besides the injection pump. Any input is appreciated as I've been at this for two weekends now and would like to get things back up and running again! -Andrew
Also when i assembled the pump i set the rack at the half way point and lined up each gear with the line on the rack. Then i placed each plunger facing the #1 Cylinder.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
30KW GENERATOR (A58214)
30KW GENERATOR...
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
