b2150 running erratically
/ b2150 running erratically #1
LDD
I was out plowing and my rpm's kept going down. Over the course of an hour it got worse and worse. So, I went down and bought some anti-gel diesel additive, after I checked the air filter (which seemed fine). The machine fired right up and ran well for maybe two minutes then started the same stuff. Next, I pulled the fuel filter and it was totally gunked up so I cleaned it based on the instructions in the manual. Then it said that before starting to bleed the injection pump. I took this to mean bleed the fuel lines which there were directions for in the manual. (No directions for bleeding the injection pump??) So I bled the lines and the machine fired right up nice and healthy. Then, it stalled and I have not been able to start it? Any help/ideas would be greatly appreciated. Is there something I'm missing with "bleeding the pump"? We're in the middle of a blizzard and I need the thing running...thanks.
/ b2150 running erratically #2
First step, loosen the fuel filter bowl with the petcock open, let the filter fill up with fuel. Next open the thumb wheel on the inlet line to the injection pump. Then crack all 4 injector lines at the injector, move the hand throttle to full throttle, crank the engine over until you have fuel coming out of all 4 lines.
When you loosened the filter bowl you should have gotten decent flow out of the filter. If all you got was a trickle, then the outlet of the tank or the fuel hose could be plugged. If you had good flow at the filter and after a couple of minutes (in 30 second intervals giving the starter a rest in between) you still don't have fuel coming out at the injector lines, you have another air pocket between the filter and injection pump. If that is the case you need to pull the fuel line off at the inlet side of the transfer pump and make sure you have fuel there. It is gravity fed to that point so having a full tank of fuel will help. Once you have fuel there, reconnect that line and pull of the line at the inlet side of the injection pump. Crank the engine over, you should get good heavy squirts of fuel. If you get next to no flow then the transfer pump is bad. If you get good flow there reconnect the line and crank the engine over again until you get fuel at the injectors. Tighten the lines and move the throttle back down between idle and half throttle. Preheat the glow plugs and start the machine. Once it is running close the thumbwheel on the injection pump.
Brian
When I crack the injectors do I keep the top bolt(with the line going in) stationary and loosen the bottom bolt or the other way round??
/ b2150 running erratically #4
You are loosening the line at the injector right? Don't loosen them at the injection pump, if you back off a delivery valve it will not pump fuel through that injector. You should be loosening the top nut, the lower nut holds the return line. If the whole injector is turning when you are loosening the line, you need to hold the injector while you loosen the line. Then you will have to retighten the injector,
Brian
Ok, so I need to loosen them on top of the block, not at the injection pump, right?
/ b2150 running erratically #7
1st things 1st you need to get in warm place or more anti gel in it. Then you need to get it warmed up an get all the nasty fuel out and good fuel with anti gel in it. Best of luck it will be a lesson that you never forget.
Just plowed the driveway man, can't thank you enough. I ran it for about 1/2 hr. and it ran great, with only one little hitch. Do you think maybe I have a pump going or maybe it was just a little piece of gunk in the lines yet?? I bought the tractor last January and did quite a bit of maintenance but I didn't clean the fuel filter and when I cracked it tonight I seriously doubt it has ever been cleaned, there was tons of junk in it.
Thanks again,
Josh
/ b2150 running erratically #9
I would guess it was a little air bubble. I would get a new filter if you haven't already.
Glad I could help.
Brian
Ok, it's back to losing RPMs...I think there may still be some air in the system. There are thumb screws to bleed one section but I'd like to do the whole thing to make sure. Should I start from the line going into the filter and work that way or should I start at the block and work back?
/ b2150 running erratically #11
Start at the line from the tank to the filter and go toward the injection pump. I have seen the tanks on the B2150's shed their coating inside the tank, that is why it is important to make sure you are getting good flow to the filter and that the tank or fuel line is not plugged. As was mentioned, if your fuel is gelled, that needs to be corrected first. I don't normally think about that, being a California boy where we see temps below freezing only a few days a year.
brian
Yeah, I added some anti-gel/injection cleaner...now that you mention the interior of the tank coming off I have to wonder. When I cleaned the filter last night most of the junk in there had a rust/orange flake consistency, almost like some sort of paint. Should the flow be a constant stream from the tank line or more of a dribble?
/ b2150 running erratically #13
A constant stream. The tank lining is more of an off white light gray color. You can take a flashlight and look in the tank to see what is going on. If you are getting just a dribble at the hose going to the filter, the next thing I would do is pull the hose off the bottom of the tank. If it just dribbles out of the tank then it is plugged. If you are getting good flow out of the tank then the line is plugged.
Brian
Yeah, it's just a dribble. I pulled the fuel filter again and there was a bunch of junk in it. I went back to the pan I used last night to clean it and looked and there's plenty of black sediment plus flecks of paint. Cleaned the filter again and it was dirty. I also looked in the tank and from what I can see there's stuff there. I think I'm going to have to flush the whole tank and lines. That's an inside job though, so I need to find a place to take it. I really appreciate your guidance on this man. Any guidance for the flushing of the tank? And, what should I do if in fact the inside of the tank is coming off as it appears to be? Get a new tank??
/ b2150 running erratically #15
I have sent them out and had them recoated, but that was years ago. Out here in California they have pretty much shut down all of the places that used to do it, along with most radiator repair shops too. You might be able find someone in your area to do it.
Brian
/ b2150 running erratically #16
Look for an epoxy tank paint. I know they do a lot of old motorcycles this way. You mix it up and keep sloshing the tank around while it dries, but no personal experience. Try a couple good bile shops.
