Name this mystery part!
   / Name this mystery part! #1
Griffey
Northern Michigan
B7610
I did some work this weekend and then I ended up finding this bolt and rubber piece in my drive way. I am going to start looking through the owners manual, but I thought maybe I'd check to see if anyone recognized the part here. I attached a picture. Any guess to where it came from?
   / Name this mystery part! #3
Check the fenders and cab for a similar type bolt and then go looking for an empty hole. /forums/images/graemlins/grin.gif
Egon
   / Name this mystery part! #4
Egon
   / Name this mystery part! #5
The rubber part appears to be like a vibration damper. If you have cab, I'd look there. Also, maybe radiator mount?????
Good luck.
ron
   / Name this mystery part! #6
Good luck.
ron
   / Name this mystery part! #7
</font><font color="blue" class="small">( Also, maybe radiator mount?????)</font>
That was my first thought.
   / Name this mystery part! #8
   / Name this mystery part! #9
It is a cushion nut and bolt, commonly used by Kubota on sheet metal to metal connections, such as cowlings, hoods, platform, ect.
What did you remove? Sometimes you have to hold them from the back to get them to tighten properly...they are sort of like a compression fitting.
   / Name this mystery part! #10
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
(10) UNUSED SDLANCH 2.5CMX3M RATCHET STRAPS (A58375)
(10) UNUSED...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
(4) Motreal ST2051/7515 Tires (A57149)
(4) Motreal...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
SDLanch SDLGC80 Electric Golf Cart (A57149)
SDLanch SDLGC80...
