Name this mystery part!
   / Name this mystery part! #1
Griffey
Northern Michigan
B7610
I did some work this weekend and then I ended up finding this bolt and rubber piece in my drive way. I am going to start looking through the owners manual, but I thought maybe I'd check to see if anyone recognized the part here. I attached a picture. Any guess to where it came from?
   / Name this mystery part! #3
Check the fenders and cab for a similar type bolt and then go looking for an empty hole. /forums/images/graemlins/grin.gif
Egon
   / Name this mystery part! #4
Egon
   / Name this mystery part! #5
The rubber part appears to be like a vibration damper. If you have cab, I'd look there. Also, maybe radiator mount?????
Good luck.
ron
   / Name this mystery part! #6
Good luck.
ron
   / Name this mystery part! #7
</font><font color="blue" class="small">( Also, maybe radiator mount?????)</font>
That was my first thought.
   / Name this mystery part! #8
   / Name this mystery part! #9
It is a cushion nut and bolt, commonly used by Kubota on sheet metal to metal connections, such as cowlings, hoods, platform, ect.
What did you remove? Sometimes you have to hold them from the back to get them to tighten properly...they are sort of like a compression fitting.
   / Name this mystery part! #10
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
10' Dump Truck Snow Plow (A55272)
10' Dump Truck...
1997 PETERBILT 387 CAB CHASSIS TRUCK (A59575)
1997 PETERBILT 387...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Toro (A56857)
Toro (A56857)
