Nasty Little Wood Ticks
   / Nasty Little Wood Ticks #31
Removing Ticks.
I've heard/read and personaly found that placing a small container filled with water over the tick for several minutes gets the tick to release and they can then be easily removed with a tweezer. The theory is that the tick requires air and starts to suffocate. When they are on me I use hydrogen peroxide, fill the bottle cap and use this to cover the tick for several minutes.
Egon
   / Nasty Little Wood Ticks #32
My 5 year old boy had his first tick of the year here in Southern Ohio yesterday. My neighbors also found a tick on their dog. I have been out and about alot lately especialy with Turkey scouting and have not had any ticks yet.
While I was in the Marines, one time I had over 50 ticks on me. The rest of the patrol I was part of had anywhere from ~20 - 70 or so. Once I got married, and started eating Cajun food, I had less and less problems with ticks. My father in law and brother in law, both cajus told me that the more spicy food they ate, the less problems they had from little critters of all sorts even mosquitos. I personally have empirical data that suggests this is true. My wife is the best cook in the world. She has been up since 6:30 getting lunch ready and she has allready started Monday's dinner.
As far as getting ticks off, if they are really hooked up and sucking, light a match, blow it out and use the head while hot to touch the body. They ussually back out.
Another method is a little dab of vaseline that will help coerce them out when they decide to come up for air. I ussually just grab them by the body and yank real hard, haven't had many problems with that method.
Bets solution is to discover them early. My family uses the buddy system to look out for each other as well as being aware that they are around. As kids get more experience, they are learning to feel them crawling on their skin.
Redman
   / Nasty Little Wood Ticks #33
If the ticks are on me, I usually light a match, let it burn for a moment, blow it out, and place the head of the match toward the head of the tick, making contact with him. Sometimes you have to use two or three matches in a row, but the tick usually will back out to get away from the heat, and he brings his head with him.
HILLBILLYMAN
   / Nasty Little Wood Ticks #34
There are tick removers on the market that are shaped like a small spoon, with a fine slot in the bowl. You push the bowl down onto the skin and slide the slot towards the tic to pop it off. This is the safest way.
In the emergency department I've used nylon suture (you could subsititute 2-4# test monfilament fishing line). Tie an overhand knot to make a noose, and tighten the noose around the tick at the junction of the skin and the tick (i.e. - as close to the skin as possible). As the string tightens the tick will pop off. The problem with all the irritant methods (trying to drown them, vaseline, lighted matches, etc.) is that they cause the tick to vomit into the bite, increasing your chance of tick-borne infection.
   / Nasty Little Wood Ticks #35
<font color=red>is that they cause the tick to vomit into the bite, increasing your chance of tick-borne infection.</font color=red>
Chris,
Thanks so much for that mind picture. It sure made the corn muffin I was eating go down good!/w3tcompact/icons/eyes.gif
Seed ticks are my favorite type. We have lots of deer, ergo lots of ticks. The seed tick stage is so small we have trouble even seeing them. They look like freckles. I, however, have evolved a defense. Since a really terrible case of chiggers a few years ago, I swell up nicely at the site of most insect attacks. If I get a seed tick, I develop a nice big bump that hurts and itches within minutes of the beastie digging in for lunch. Adaptation at it's finest.
Chuck
   / Nasty Little Wood Ticks #36
OW (Gee why did you pick that user name??)
I suppose I should explain it in my profile. Its because where I grew up people would get tired of getting stuck behind the old fella on the tractor on the country roads ... "Whos that old wanker on the tractor? Wish the old wanker would get on with it. GET OFF THE ROAD YOU OLD WANKER" ... and so on.
I suppose its ironic that the old wanker is now me so I picked it as a username!
   / Nasty Little Wood Ticks #37
We use Frontline on the dogs, and Guineas for the yard. The dogs still get the occasional tick os so, because they go pretty far away frome home. Usually we very rarely find ticks on us, the guineas do a wonderful job. They also keep the chiggers away and will run off snakes too.
   / Nasty Little Wood Ticks #38
Yep, the're out in force. My wife and I both found one on each of us and we took 2 off the dog. If this is any indication of the season, we are in for it in NH.David
   / Nasty Little Wood Ticks #39
I just hate it when I feel someting crawling arond in the hair at the base of the back of my neck, wipe it with my hand and come back with a tick. Done that twice last year. Wife had a couple spud in. I had one. Started getting real spun up and paranoid. Researched the tick, the diseases te carry, their life cycle, removal, prevention, and on and on.
Here is readers digest version: Use the method the DoD uses (and is approved by center for disease control and several states) Permethrin. Check it out, it is much safer than Viet Nam jungle juice (regular DEET). It degrades in contact with your skin so it is used on yor outer clothing. Different amounts give different periods and levels of protection. DoD method I followed last year used 13.3% permethrin. The best price I found was $26/8 oz. This year I found 10% at $50/gal (multiple years supply for multiple users) or $10/8 oz for 10%. Used same formula just 1 1/3 oz of 10% instead of 1 oz of13.3%.
Here is the drill: 1 1/3 oz of 10% permethrin and 14 2/3 oz of water (makes a pint). Roll up a pair of long pants or long sleve shirt (cotton or cotton blend, more cotton the better) secure with rubber band, put into a good strong ziplock bag (freezer bags are real good), add the well shaken permethrin, squeeze out the excess air and seal the bag. It is ok to put two pair of pants in a large bagm just double the amount of mixture.
Treat outer clothing only not your underwear (not for panties or bra) Treat socks, pants, and shirts (long or short sleeve). Let it wick through the material for at least two hours, preferably longer to ensure a good distrubution. Clothing need not be saturated just moistened evenly. This amount is to put a certain number of miligrams per whatever area of cloth. This is all available to the surfer of the web if you want to get it first hand.
Let the clothing dry thoroughly before wearing. Permethrin solution may have some petroleum distilate but that will evaporate and the clothes become scent free. Wear rubber gloves to handle treated clothing while it is wet as a precaution.
This treatment will last through 52 weekly washings in hot detergent. Ticks will get sick and fall off after walking about a foot across treated cloth. Mosquitos will not bite you through treated cloth. Likewise chiggers and other stuff is repelled or sickened or killed but there is a really good human safety record. For maximum protection tuck your pants in your socks to force the little vampires to crawl furter to get to you and they wont finish their death march.
After we treated our clothes last year we got no ticks or chiggers at all at any time or any mosquito bites where we were protected by treated clothes. This year with three people wearing treated clothes we have seen one tick and that was dead floating in bath water having aparently died trying. There are lots of ticks in our environment but we feel pretty safe fishing, working outside, and running around on our land.
For virtually 100% protection from all flying stuff you need to add micro-encapsulated time release DEET cream to your exposed flesh (not covered by treated clothing). This is a safer form of DEET. It lasts longe rand does a better job than regular DEET but exposes your skin to a much lower dose. Yo can wash it off when the risk is gone like when yo return indoors for the day.
Additional tick comments: Never grab a tick to remove it. Squeezing a tick expells its stomach contents into the host which is you, your kid, dog, who/whatever just like a hypodermic needle giving a shot. Never use a hot pin, cigarette, turpentine, bleach, etc etc. No vaseline or any other substance. research has shown that the only chemicals or drugs that cause a tick to release are bad for the host as well. There are tick removal appliances of modest cost. These allow you to get the tick by the skinny area between his biting parts and abdomen (like a neck) and slowly pull it out with a slight rotary motion to help break lose the cement he secretes to glue his mouth to you. Lyme disease and a bunch of other nasties are carried by some ticks. In NJ (hope you don't live there) something like 40% of the deer ticks carry lyme disease.
Hope this didn't creep you out. Anyway we are again tick free and it is a wonderful feeling to not have to worry aout ticks giving you some disease or even discomfort.
There is lots of good information from reputable sources on the web about ticks and preventing their bites, even university studies of the effectiveness of various tick removal devices. ( I have two kinds) Don't expect to need them but they are cheap insurance and come with a small magnifying glass to aid in tick identification/removal shoud it ever be required again.
Patrick
   / Nasty Little Wood Ticks #40
There is more than meets the eye with this removal stuff... I just did a web search and came up with a useful site.
Basically, you want to get them out quick because the longer they are in the more chance of transmitting the disease. Also, using one of the commercially available devices seems to be more effective (getting them out "intact" and without discharging their load) in most cases than "medium sized tweezers". Plus, they state that "folk" methods (hot match, Vaseline, etc.) don't work... I'll let you guys read it...
Check out:
<A target="_blank" HREF=http://www.biosci.ohio-state.edu/~acarolog/acar-hp.htm>http://www.biosci.ohio-state.edu/~acarolog/acar-hp.htm</A>
Enjoy! /w3tcompact/icons/wink.gif
2016 Ford F-550 Altec Bucket Truck (A51692)
2016 Ford F-550...
198367 (A51243)
198367 (A51243)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Charlotte County (A50323)
Charlotte County...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
