Natural gas conversion - where to feed the gas
   / Natural gas conversion - where to feed the gas #1
Travelover
Elite Member
Washington
B7100
I'm converting a small gas generator to allow for it to be able to run on gasoline or natural gas. Most of the commercially available kits add a small venturi between the between the carb and the air cleaner. This causes packaging problems and messes with the choke linkage, so I'd like to apply the gas either to a tapped inlet on the manifold or directly in front of the inlet in the air cleaner box. The inlet pipe has to have a small vacuum in order to open the regulator valve, which functions as a safety device so the gas quits flowing if the engine stops.
Anyone done this or have experience with propane / natural gas engine intake systems?
Generator Conversion Kits to Propane and Natural Gas.
   / Natural gas conversion - where to feed the gas #2
Good luck- I’ll give this a bump for you just cuz I’m curious.
If I’m reading it right it looks like you are trying to add propane (like a diesel with propane injection) rather than eliminate gasoline. The only tri fuel gen I’ve seen was an old Onan. But that required some carb parts change etc to switch from one fuel to another. I’m not sure how a simple valve that opens with vacuum could be the only fuel. Starting and cold running are two areas that would need more attention.
I'm adding natural gas, not propane. That is relevant because propane requires a bit more effort to get it properly vaporized and mixed with the incoming air than natural gas. There are several companies that sell these conversion kits and they all have the same basic components - I linked one of them in my initial post. Generators are easier to convert to natural gas or propane, as they run at a constant rpm.
   / Natural gas conversion - where to feed the gas #4
You still need some kind of a venturi device to meter the natural gas. Yes generators run at a constant speed but they don't run under a constant load.
   / Natural gas conversion - where to feed the gas #5
I converted my generac 10 hp Briggs over to Propane . I did not buy a kit , I used a on demand regulator like you are talking about. It was intended for a floor scrubber . I removed the carb to get to the plastic spacer that is between the carb and the block. I drilled and tapped a hole for a barb fitting , this was for the vacuum line that shuts off the full if the engine quits,any place on the engine side of the throttle plate will work, like you said safety devise . I drilled a hole in the back of the plastic air cleaner just a little smaller then the rubber vapor feed hose from the regulator , pulled it over in front of the inlet , cut the hose at a little angle to get it close , this is on the engine side of the air FILTER , this is where you get the vacuum to open the diaphragm in the regulator ,the closer the regulator the better because less hose to build vacuum in,be sure to mount the regulator vertical not horizontal, if laid down flat the weight of the diaphragm will through off the calibration of your regulator , mine starts second pull. I put the same regulator on my Toro Grounds Master and on my Case loader with my only problem is the 20 pound grill tank will freeze up at times but not many because of the larger engines calling for more vapor then the tank will naturally make.
Thanks, this is exactly the kind of information I was looking for. The regulator I'm using, a Garretson, is the same one used by the three major retrofit companies. It does not use a separate vacuum line, it is set up so the engine has to pull the gas through. I think this also allows for varying gas feed depending on load.
Regulator Garretson KN Beam Impco how valve works for Propane or Natural gas generator - YouTube
   / Natural gas conversion - where to feed the gas #7
Yes, it sounds and runs like it is on gasoline, throttles up and idles and follows the Governor for rpms . I remember my generator running a little rich, slight black smoke when I first started it after converting it , they make a adjustable inline valve to correct it , goes between the regulator and carb. I pinched my vapor feed line a little and it cleared right up so I cut a one inch long piece of thin hose that fit inside the vapor feed line to restrict it like a orifice. Got lucky first time, runs on propane better then gasoline, well better then 2 year old gasoline that I normally had in the tank when I needed it.
   / Natural gas conversion - where to feed the gas #8
i converted two EU2000 inverter generators using the US Carb 'snorkel' kit to run on propane.. took longer to figure out where to mount the regulator than do the actual conversion..
Ran both generators for a total of 30 hrs a few months back without any issues.. Much better set up than trying to store 15 gallons of gas
brian
   / Natural gas conversion - where to feed the gas #9
every now and then US Carb run holiday specials - I got my kits for 50% off normal price..
Yes, the part that feeds the gas at the carb seems overpriced for what it is.
   / Natural gas conversion - where to feed the gas #11
Subscribed. Hope to learn more about the Petro to NG conversion. Specifically my question is about starting the generator on Petro and then switching to NG once running. I understand without electric start it's nearly impossible to get one stated on NG.
   / Natural gas conversion - where to feed the gas #12
Some regulators have a primer button you push to manually hold the diaphragm open like the one Travelover has per the youtube video he attached, you could compare it to a choke on a gasoline carburetor . On forklifts, automobiles they have a electric solenoid mounted over the primer button so when the electric starter is activated the solenoid pushes and holds the button down until you stop using the starter . Some regulators like Travelover has do not have the built in safety valve that takes a second small vacuum hose , this shuts off the vapor if the engine was to quit. To use the device indoors it is normal to have, so there is a whole different device that looks like a regulator but is a safety fuel shut off that should be but will still work with out, it is mounted between the tank/fuel supply and the regulator and has a small vacuum hose that is ported in somewhere between the throttle plate and the engine block for constant vacuum. With all this going on some can be hard to start, My loader has a V4 Wisconsin and I start it on gasoline , it has a electric fuel pump with a switch on it , after it starts I shut off the fuel pump and when it starts surging running out of gasoline I turn on the propane bottle , not a exact science if I am a little early it just blows black smoke and runs bad for a few seconds.My guess is that it is the engine is wore out and not enough vacuum to open and draw the propane until the RPM's are higher then the starter can turn.
Some regulators have a primer button you push to manually hold the diaphragm open like the one Travelover has per the youtube video he attached, you could compare it to a choke on a gasoline carburetor . ...........
Rocky nailed it - the primer button holds the diaphragm open and allows the gas to purge the air in the lines. There are dozens of YouTube videos on this and in many, they just hold the primer button in until they can smell gas. Then pull the rope or engage the starter and you are ready to go. Without a primer, you'd need to crank it a long time especially if you had a lengthy hose.
So, I got a new used manifold yesterday off eBay. Can I feed the natural gas directly into the manifold? It seems like there is a good vacuum there - that is where vacuum is pulled on a car to operate brakes, etc. What would be the minimum diameter barb for an 11 HP engine?
   / Natural gas conversion - where to feed the gas #15
Do you mean with out a carburetor ? If so the answer is no. It needs to use the throttle plate in the carburetor. The Inside Diameter on my hose from the regulator to the carb is 3/8 inch , so you need to know what size pipe thread is in your regulator or take it with you to the hardware store. If I was guessing it would be 3/8 npt (national pipe thread) to 3/8 hose barb, the hose is not under pressure so any thin flexible hose will work . It is important that your hose ends up between the carb and the air filter in the air filter box, it needs the negative pressure that will not be on the other side of the filter. other then drilling a hole big enough to get that hose into the air filter box you will not alter anything else from a normal running gasoline engine, in fact if you run out of propane turn on the gasoline and start it back up.
No, I'm leaving the carburetor in place so it can also run on gasoline if need be. I'm proposing drilling and tapping the manifold between the carb and the engine and installing a barbed fitting to attach the gas hose.
Yes, the outlet of the regulator is 3/8" NPT. My question was, "what is the necessary inside diameter of hose between the regulator and the engine". It sounds like you were successful with 3/8"
Why would the gas inlet point need to be between the carb and the air filter as opposed to directly into the manifold as described above? With the carburetor installed, there is a vacuum (negative pressure) in the manifold.
   / Natural gas conversion - where to feed the gas #17
The throttle plate in the carburetor is going to control the amount of vacuum on the Regulator , it is a Demand Regulator , more vacuum = more fuel , this regulator is like a carburetor supplying the right amount of fuel to air mix . In the intake between the carb and engine block is constant high vacuum and would give it uncontrolled amount of fuel to air mix, if it did start it would be like the choke full on when running on gasoline. If you look inside the gasoline carburetor you will see the tube the gasoline comes out of is in-between the throttle plate and the chock plate , this regulator needs to be separated from the engine with the throttle plate .
Good explanation, thank you. I'll need to figure out a way to feed the gas into the air cleaner box just in front of the carb inlet to be sure I have an adequate pressure drop.
The picture below is what is under the paper air filter. There is an offset plate covering the carburetor inlet that extends down to the lower right to cover the crankcase breather tube inlet. I think that plate helps increase the vacuum at the inlet of the breather tube. I'm thinking of tapping a hole in the upper left corner for a natural gas inlet barb and extending the existing plate over the barb base inlet. This extension should give me additional vacuum at the gas inlet.
Does this sound reasonable?
   / Natural gas conversion - where to feed the gas #20
This is what I did, yes it egg shaped the hose a bit.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2017 Ford F-550 (A55973)
2017 Ford F-550...
