Neat trick using loader as a box scraper!
   / Neat trick using loader as a box scraper! #11
Yes. set your bucket flat on the ground and tilt it forward as to dump. it will pick up the front of your tractor. works great but if your on a standard make sure you in reverse before letting out the clutch or youll have a trench to fill?? jb
   / Neat trick using loader as a box scraper! #12
Nathan,
When the bucket is flat on the ground, both the front cutting edge and the back of the bucket are touching the ground. When draging the bucket backwards, it will smooth out the ground you drive over. This is how I fill ruts, smooth gravel and just about everything.
If you tilt the front cutting edge up so it's slightly off the ground, but the back of the bucket is touching, it will dig into the ground to a small degree. I do this when I have a pile of dirt that's too small to dig out, but bigger then I want to smooth with the flat bottom of the bucket.
The more weight you have on the front bucket, the more effective it is. For this reason, I usually push the bucket all the way down, which results in my front tires rising off the ground. I can't steer, so I just go straight back until I either smooth out the area I'm working on, or I start to change directions and need to re-align myself.
On bigger construction tractors, they have a "float" feature that helps keep the bucket level when back draging. This is a normal, every day job for a backhoe operator, but for some reason, compact tractor owners seem to not do this and rely on the box blade.
Eddie
   / Neat trick using loader as a box scraper! #13
Only time I use the cutting edge like that is to get really close to something, like a wall or tree. Then use the heel of the bucket.
Rob
   / Neat trick using loader as a box scraper! #14
Nathan,
Looks like we may have ganged up on you pretty good. I never like to see anyone damage their equipment and that is why I posted on this thread and I'm sure that most if not all of the other members that have posted are the same way. Sorry if it hasn't come across that way.
   / Neat trick using loader as a box scraper! #15
JerryG said:
Nathan,
You need to be very careful blading like that. The cylinders are not designed to be used like that. The nut can be broken off of the gland and the rods can be bent very easily. Some of the manufactures, if not all of them recommend against doing back grading with the bucket turned down over about a 30* angle.
Gee! I learned something today too!
Thanks, Jerry!
   / Neat trick using loader as a box scraper! #16
I have been told that it is HARD on hydralic pumps!
mark
   / Neat trick using loader as a box scraper! #17
I'm actually going to have to read my 300cx manual now. I've done this technique, be it good or bad, a few times without issue. I wonder if other non-green brands lack the strength of the green 300cx? After reading many threads, it seems some orange hydraulic cylinders can be bent way too easily.
   / Neat trick using loader as a box scraper! #18
Im a little confused.. Can someone post pics of what not to do AND the proper way??
sorry to be so dense..
Brian
   / Neat trick using loader as a box scraper! #19
Actually, once you get good with your loader, you should be able to grade with it while going forward; not needing to back drag in most cases. Setting the angle of the bucket is important. (Also, a hint is that that a full, or nearly full bucket will grade better than an empty one... this is also true for dozer blades.)
   / Neat trick using loader as a box scraper! #20
Brian
Copied this out of my FEL owner's manual for the graphics. (and photoshopped an additional NOT THIS at bottom)
Correct way: Figure 25 is what EddieWalker and others were referring to.
Wrong way: Pulling bucket in fully dumped position, which would be similar to Fig. 27 in forward direction. The FEL is not stressed to handle that angle.
Like EddieWalker was saying, tilting the bucket up slightly will allow the heel of the bucket to dig into the ground slightly when pulling a loaded bucket in reverse with the front wheels off the ground.
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
White 6138 Planter (A59814)
White 6138 Planter...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
EZ loader trailer (A56857)
EZ loader trailer...
2006 Mac Truck CXN613 (A56436)
2006 Mac Truck...
John Deere 1025R (A53317)
John Deere 1025R...
