Sprayer need a pull-behind sprayer for driveway weeds
   / need a pull-behind sprayer for driveway weeds #1
Buckie
North Carolina
JD 2210
hello all. I have a new 2210 with Imatch. since I live in the country, I have a very long gravel drivway that persists in getting weeds in it. In the past I have used a backpack tank sprayer and manually hit the weeds with various killer products. Am thinking there must be some kind of pull-behind tank sprayer (relatively cheap) that I can use with the 2210.....one with a long horizontal tube/openings that sprays out a path of weed killer. does JD have such a thing? some other brand or aftermarket product? thanks, buckie
   / need a pull-behind sprayer for driveway weeds #2
Agri-Supply sells several at very reasonable prices, sometimes even less than Northern or other places. Here is a link to their most recent catalog. Click on the catalog to get the page thumbnails. Sprayers are on the first few pages.
Agri-Supply catalog
   / need a pull-behind sprayer for driveway weeds #3
A 15-25 gallon sprayer that would sit on a "carry-all" would do the job and be less money than a pull-behind.
   / need a pull-behind sprayer for driveway weeds #4
I already had a carry-all which is great for moving stuff around. It turns the tractor into a virtual forklift, except it can't lift stuff high up. From N.H. Northern, I bought a $89, 15 gal. sprayer which was designed to be bungee strapped to the back of an ATV. I put a wood plank the width & length of the tank on the carry-all and bungee the sprayer in place. This was a lot cheaper than the kind already on wheels. Since it is lightweight, I can lift it and store it up high on a shelf or in the garage trusses. A sprayer with its own frame and wheels is too heavy for this & takes up precious garage space.
   / need a pull-behind sprayer for driveway weeds #6
Femco makes a pretty decent tow behind sprayer. I use mine a lot. It puts out a pattern about 5 foot wide. Works great for spraying the yard with 24d and it has a wand for hand spraying. I am thinking you buy one for around $225.
   / need a pull-behind sprayer for driveway weeds #7
after getting three prices from tractor dealers, and looking on the net. I found a supplier in CA that had a great price. They shipped it in the afternoon, got it the next morning. After getting the Agri Supply catalog i found i left a couple hundred dollars on the table. Their prices look hard to beat if they have one you like.
I checked the agri supply catalog and found that they actually have a retail store fairly close to me. so, will make a trip to their store this weekend. I think the pull-behind 15 gal sprayer is about $245 unassembled. my question is whether the length of wire, from the sprayer to the battery on my 2210, is going to be long enough. I may have to splice in some length.
What's a "carry-all"? I hate to ask so many dumb questions. Am just learning about this stuff. thanks to everyone for the help!
   / need a pull-behind sprayer for driveway weeds #9
A carry all is just a box that mounts to the rear of your tractor like an attachment ie a box blade or rake would. It uses the 3pt hitch its just another way to carry stuff.
   / need a pull-behind sprayer for driveway weeds #10
I carry my tank in my FEL, it's not far to the battery from there and I use small clamps to attach it to the terminals temorarily. The hose is looped along a FEL arm so the wand is at hand's reach. From there I have a hose attachment rather than a spray head on the wand and that hose runs to a boom pole "U" bolted to the tractor's lower arms. It works well for the 4 times a year it's used and easy to switch between boom pole and wand sprayer.
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1770 (A58375)
1770 (A58375)
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
Bobcat T590 (A53317)
Cat CB24B (A60462)
Cat CB24B (A60462)
