VRF201 said:
Hi and hello to all!
Newbie here!
I just purchased a house with 5 acres and a Kubota GS1800 54 cut.
I'm looking to upgrade to a newer bigger tractor to maintain the property.
My starting point is 30 hp. The land is mostly grass and flat with some brush removing needs.
Would like to stay under 18,000 if possible?
Thanks to all that reply!
VRF201 (Roy)
While I can't personally see the need for a permanent tractor for 5 acres (rent one, clear the brush, level the worst obstructions and mow with the 54 inch unit) tractors are fun and if it blows your skirt up and have the $ go for it.
A dealer in Ada, Oklahoma is selling 50 HP Kubota tractors with 6 ft brush hog, 6 ft box blade, front end loader, on an 18 ft tandem axle electric brake trailer as a package deal for $19K. A friend/neighbor shopped that deal with Dinsmore Kubota in Shawnee, Oklahoma and got the same inventory for $200 less. There is also a package deal for a smaller Kubota tractor with 5 ft box blade, 5 ft brush hog, FEL, and 16 ft trailer for $16K.
I spent the night Saturday night with the proud owner of a Montana (essentially a JD without the yellow stripe.) He insisted I try it out so I did briefly. What can I say, it is a tractor, a nice tractor. Fit and finish look good, Mitsubishi diesel is hard to fault, the cab is roomier than mine (you probably don't need the expense of a cab and A/C with 5 acres) and the spring loaded seat handles my weight better than my Kubota. Anyway, you can get a lot of tractor and equipment for $19K or less, hopefully less as, really, 5 acres is not all that much land once you get over the few feet by a few more feet tract lot mentality.
My place is medium small to average in this area and is 160 acres. There isn't much I can't do with my 40 HP Kubota(within reason.) When projects are too big for my tractor then they are usually too big for a 100 HP tractor and I hire a dozer.
Unless you are doing a lot of terra forming, with 5 acres a good stout little diesel tractor might be all you need. I suggest you consider a Kubota BX or B series tractor or alternate brand equivalent.
Of course it would be fun (and effective) to call in a massive air strike with napalm and fuel-air bombs to clear the ants at a picnic site but it might be considered overkill and might not be cost effective. You will find plenty of things besides an oversized tractor to spend money on more appropriately. Do you garden? There are plows, disks, rototillers, spray rigs for weed and feed (garden and yard), and on and on for the smaller tractors.
I may be a minority voice crying in the wilderness but I think unless you are doing a lot of HD terraforming you are wasting money to go over 25HP with 5 acres. Put $ in a hydrostat tranny, aux hydraulic outlets for accessories, hydraulic top and tilt, and such and you will be far happier in the long run, I suspect, than you will having an oversized tractor and fewer implements.
Pat
