SoundGuy, I don't think I said anything about what someone wanted in my discussion, I think I talked about what they need. I screw up enough on my own without being misquoted. If the above is in variance with fact, then believe what I said here to be my true intent.
I don't care what you "want." If you buy significantly more than you need it is wasteful regarding the context of what you need to do the work. It is not a crime nor a misdemeanor and you can justify it or rationalize it as fun, "but I got a bargain", "I need it to stroke my ego", or any number of reasons. It is OK with me.
I used to drive a 165 MPH capable sports car. Did I need all that speed capability. Did I really NEED whip lash inducing acceleration at speeds approaching 100MPH. OF course not. I justified/rationalized that car with FUN and WANT, not need.
You may someday have to explain your actions to the "GREEN POLICE" (I'm past the statute of limitations) and suffer being picketed by climate change activists but luckily Al Gore hasn't stirred the mob up that much, yet.
I don't think you and I are in disagreement with your tractor choice (and I didn't get that impression from MossRoad either) although we may have a few areas in which we are not in agreement in what constitutes proper advice for Roy.
Roy on the other hand is sending mixed messages, at best. He delineates a budget and when GOOD advice suggests something less expensive he replies with "BUT I LIKE MORE POWER" comments. Yet another disciple of Tim Taylor.
Roy, about that requirements list? How can you possibly hope to get a tractor close to your needs, or wants for that matter, if you don't know what you want it to be able to do?
It has been suggested that I enroll in one of the 12 step programs to break my adherence to the Tim Taylor school of sizing engines etc.
Sound Guy, my intent is not to insist my way is right and yours is wrong. I tried to encourage Roy to not waste $ on HP and tractor size he doesn't NEED. Now that I see that is what he WANTS and NEEDS don't enter into it I am through until or unless Roy can state for us his requirements in a prioritized list so we can offer REAL help in an orderly fashion.
I know I set myself up as a target and I don't fault you for taking a shot but please don't misquote me or put words in my mouth, I am fully capable of messing up without assistance.
... and oh by the way, Roy, if you are reading this... The top lift on "standard tractors is a mechanically adjusted turn buckle arrangement or similar. You have to get off the tractor, make a little adjustment, try it out, refine it tryu it out , REPEAT till you get it right. This assumes a static problem which is NOT THE CASE in many instances. So you just have to suffer to have it wrong much of the time i a varying terrain situation. Hydraulic top lift replaces the mechanical adjustment and allows you to make fingertip adjustments without stopping so you can touch it up dynamically as you need. I use it to elevate my brush hog so I can back over trees up to 4-5 inches in diameter and slowly lower the cutter, eating the tree down to the ground. I use it to give me much finer control dribbling dirt or gravel out the back of the box blade, way finer control that the lower arms.
Hydraulic tilt lets you replace the fixed (not adjustable side with the manual adjustment (turn buckle thingy or equivalent) and replace the manually adjustable one with the hydraulic one. Between the two you get amazing control of the box blade (I can tilt mine way up and dig a road side ditch) or you can tilt the brush hog when driving down the side of a driveway or edge of a pond dam or any time it is handy. It gives you finger tip control of the tilt of the 3PH.
OK, this is where traditionally a bunch of guys line up, with sour grapes in hand, to say they and their ancestors have tractored for centuries, never had any hydraulics at all and never missed nor needed them. I think you are too smart to think finger tip hydraulic adjustment is a bad idea. It isn't just convenience, it is practicality. In theory you can move a sand pile one grain at a time but in practice it is not practical. In theory you could maybe drive a few feet, get down make an adjustment, drive another few feet (lather rinse repeat) but you (and no one else in their right mind) will do that so they suffer to do the best they can with the primitive adjust ability of the manual control.
Check with a professional landscaper and see what they say about hydraulic adjustments vs manaul ones. If you intend to use your tractor for landscaping(we still don't know what you want to ws=do wiltlh the tractor, do you?) and related jobs you will be much happier with hydraulic top and tilt than "MORE POWER!) but if you want to spend more then get the hydraulic adjustments AND THEN all the power your budget, wife, or sanity, will allow.
Oh and by the way... as in many other fields of endeavor it is not just the gun but the gunner that makes the most difference. I don't care how many pounds of artist stuff you buy, if you have no artistic talent you will not crank out a masterpiece no matter how expensive your canvas, easel, or brush.
Pat
