Need Advice on Buying An Equipment Trailer
   / Need Advice on Buying An Equipment Trailer #11
I would go no smaller than 18'. I have a MX5100 (50 HP) and I can squeeze my tractor, rear blade on with very little room to spare. Would't mind having another 2' or so....
Totally agree- even my 40 hp ford and the brush cutter is a little long for my 20 foot tilt trailer. mowing Kim & Dons finished 009.JPG
It would also be over weight if limited to 6850 lbs. on the trailer and or trucks load capacity
tractor 3800 + 1500 loader +900(loaded 14.9x28") 800lbs. Old ford 6ft. brush cutter + 700lbs. riding mower = 7700lbs. ... it adds up quick
You will have to be careful in your choices- to meet your weight limitations
Thanks to everyone for the advice. My tractor weighs 4585 with cab and then have the loader plus tires filled with beet juice. I am up to 6500 real quick. I would not be hauling anything other than the tractor at one time. And I forgot to mention I am looking at a bumper pull.
   / Need Advice on Buying An Equipment Trailer #13
Rethink hauling just the tractor. That's like going fishing and taking only the pole but leaving the beer and tackle box at home. A tractor without implements is pretty worthless.
I usually have one under the FEL, one on the 3 point, and one in my trucks bed.
Chris
   / Need Advice on Buying An Equipment Trailer #14
I went from a 18' to a 22'. It allows me to adjust the location of the tractor depending on what truck I am pulling it with. Pull the tractor all the way to the front with the F250 and about 2' back with the F150. The length of the trailer has never been a issue with the bumper pull. CJ
   / Need Advice on Buying An Equipment Trailer #15
Not to hijack the thread but what is the difference between an equipment trailer and a car hauler? Is one a deck over and the other a a deck between? I always thought a car hauler was the one axle thing that you drove the front end of a car on and towed but the reference on message #9 say otherwise.
I would agree go with the 18 ft min; better the 20 ft trailer. I have an 18 and often wish I had the 20 ft
   / Need Advice on Buying An Equipment Trailer #16
I would agree go with the 18 ft min better the 20 ft trailer. I have an 18 and often wish I had the 20 ft
The 1 axle thing is a car dolly.
Several answers, some, all or none can be relevant on any given trailer:
1) Marketing (A.K.A nothing)
2) Equipment trailers tend to have higher load ratings & be a bit beefier/heavier than a car hauler
3) Car haulers tend to care a little more about not blocking the door when you go to get out of the car
4) Car haulers tend to have a smoother loading system (longer ramps, lower deck, etc.) so your low car can get up without getting gutted, not as big of a concern for equipment
   / Need Advice on Buying An Equipment Trailer #17
http://www.tractorbynet.com/forums/...306030-car-hauler-equipment-trailer-what.html
   / Need Advice on Buying An Equipment Trailer #18
I've looked at Kaufman, PJ, Appalachian, and Texas Pride to date. I will on different occasions be hauling a Mule, or a ZTR, or a tractor. (Right now a 45 hp but am thinking about moving up to a 65 hp.) My big problem is trying to decide on length of trailer, should I go with the 16 or 18 ft. and also who makes the best trailer. Kaufman trailers bought factory direct are reasonable but I do have a PJ dealer only 12 miles away. I will be towing with a Ford F150 Ecoboost with the towing package.
Any thoughts or advice would be appreciated.
Oleozz, please call us at Kaufman if you have any questions and still need help. 866-455-7444
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2006 TerraGator 8104 (A55314)
2006 TerraGator...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
