Need Advice on Buying An Equipment Trailer
   / Need Advice on Buying An Equipment Trailer #11
I would go no smaller than 18'. I have a MX5100 (50 HP) and I can squeeze my tractor, rear blade on with very little room to spare. Would't mind having another 2' or so....
Totally agree- even my 40 hp ford and the brush cutter is a little long for my 20 foot tilt trailer. mowing Kim & Dons finished 009.JPG
It would also be over weight if limited to 6850 lbs. on the trailer and or trucks load capacity
tractor 3800 + 1500 loader +900(loaded 14.9x28") 800lbs. Old ford 6ft. brush cutter + 700lbs. riding mower = 7700lbs. ... it adds up quick
You will have to be careful in your choices- to meet your weight limitations
Thanks to everyone for the advice. My tractor weighs 4585 with cab and then have the loader plus tires filled with beet juice. I am up to 6500 real quick. I would not be hauling anything other than the tractor at one time. And I forgot to mention I am looking at a bumper pull.
   / Need Advice on Buying An Equipment Trailer #13
Rethink hauling just the tractor. That's like going fishing and taking only the pole but leaving the beer and tackle box at home. A tractor without implements is pretty worthless.
I usually have one under the FEL, one on the 3 point, and one in my trucks bed.
Chris
   / Need Advice on Buying An Equipment Trailer #14
I went from a 18' to a 22'. It allows me to adjust the location of the tractor depending on what truck I am pulling it with. Pull the tractor all the way to the front with the F250 and about 2' back with the F150. The length of the trailer has never been a issue with the bumper pull. CJ
   / Need Advice on Buying An Equipment Trailer #15
Not to hijack the thread but what is the difference between an equipment trailer and a car hauler? Is one a deck over and the other a a deck between? I always thought a car hauler was the one axle thing that you drove the front end of a car on and towed but the reference on message #9 say otherwise.
I would agree go with the 18 ft min; better the 20 ft trailer. I have an 18 and often wish I had the 20 ft
   / Need Advice on Buying An Equipment Trailer #16
I would agree go with the 18 ft min better the 20 ft trailer. I have an 18 and often wish I had the 20 ft
The 1 axle thing is a car dolly.
Several answers, some, all or none can be relevant on any given trailer:
1) Marketing (A.K.A nothing)
2) Equipment trailers tend to have higher load ratings & be a bit beefier/heavier than a car hauler
3) Car haulers tend to care a little more about not blocking the door when you go to get out of the car
4) Car haulers tend to have a smoother loading system (longer ramps, lower deck, etc.) so your low car can get up without getting gutted, not as big of a concern for equipment
   / Need Advice on Buying An Equipment Trailer #17
http://www.tractorbynet.com/forums/...306030-car-hauler-equipment-trailer-what.html
   / Need Advice on Buying An Equipment Trailer #18
I've looked at Kaufman, PJ, Appalachian, and Texas Pride to date. I will on different occasions be hauling a Mule, or a ZTR, or a tractor. (Right now a 45 hp but am thinking about moving up to a 65 hp.) My big problem is trying to decide on length of trailer, should I go with the 16 or 18 ft. and also who makes the best trailer. Kaufman trailers bought factory direct are reasonable but I do have a PJ dealer only 12 miles away. I will be towing with a Ford F150 Ecoboost with the towing package.
Any thoughts or advice would be appreciated.
Oleozz, please call us at Kaufman if you have any questions and still need help. 866-455-7444
2025 Swict 60in Bucket Skid Steer Attachment (A55851)
2025 Swict 60in...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
1989 Hyster H40-XL-MIL 4,000lb Diesel Forklift (A55851)
1989 Hyster...
