crackerjack222
- Joined
- Sep 12, 2011
- Messages
- 243
- Tractor
- 4430, Ford 7000, MF235
For you S TX guys, I am just outside Smiley. I dont have any experience with ratchet rake, I have a JD 55 track loader with 4/1 blade/bucket. I made a root plow that hangs off the blade and extends below the blade 18" and is 42" wide. The 555 can run that 42" blade under most mesquites and lift them out. On the largest mesquites I will push them over then root them out. 10 years ago I cleared 150 acres of 12' tall mesquite regrowth with this rig.
I have also used Remedy and Reclaim with good results, Remedy only at 1.5% in water with mixed results.
As for tires and thorns, I have gone with aircraft tires with good results. I tried foam filled first but the tires got beat up very quickly with the foam in them. They just did not last long at all, even with new tires.
