Need educated on 3 pt backhoe attachments.
   / Need educated on 3 pt backhoe attachments. #11
I and many others, own tractors that came from the dealer WITH a 3pt backhoe on them. And I bet you can still buy them that way.
Guess what ?, mine is still in 1 piece. :)
   / Need educated on 3 pt backhoe attachments. #12
Call up your color dealer of choice and ask if they warranty tractors with 3pt hoes. Most (if not all) no longer do. If it's not a problem, why?
It's possible that it may be a good way to sell you a more expensive one, I'm thinking..
   / Need educated on 3 pt backhoe attachments. #13
I'm not saying it's the best way to go. I'd love to have a sub under mine.
All I'm saying is they're not cracking in half as some folks like to believe.
If they were, we would certainly be seeing it.
Wish we could get a count of the 3pt hoes here on TBN.
   / Need educated on 3 pt backhoe attachments. #14
scesnick,
Your tractor has enough horsepower oomph to run the larger backhoes but another important consideration is the tractor's hydraulic GPM rating-again I'm sure that yours is well enough to run the larger backhoe attachments but do check the BH manufacturer's requirements. I don't remember if you said that you have a FEL-mandatory for a backhoe attachment.
   / Need educated on 3 pt backhoe attachments. #15
The "crack" a tractor has been thoroughly disputed here and the one picture that always comes up was determined to have been done by something else.
I HAD the BH70-X w/ subframe on my little B7610. I took it off to use a box-blade.
When digging I usually put lot's of weight in the FEL or I drag the tractor all over the place.
It's not TERRIBLY hard to hook up, once you get it just right. I'm going to hook up some sort of hoist eventually. I had gotten the process down to about 3 backup's (put the tractor in gear and gently press the "go pedal" w/ my hand while standing on the ground) and a little cussin' in about 10 minutes.
Definitely get a hydraulic thumb.
Get the biggest you can afford and happy hoeing!
   / Need educated on 3 pt backhoe attachments. #16
Amazingly, here are a bunch of TBN members who have seen tractors broken by three point backhoes....................
Hate to burst everyone's bubble of a hope that it's an urban legend, but someone posted a picture on this board of just this sort of thing! I think it was John Miller III, but I could be wrong. I remember how sad of a picture it was, with her back broken like that. /forums/images/graemlins/frown.gif
Henro....find that pic, and show it to your wife... /forums/images/graemlins/laugh.gif
I saw an L series Kubota with the top link mount broke out of the trans case. This was due to a 3 pt backhoe. The owner did not put know to put the reinforcing bracket onto the trans case. The bracket is "L" shaped and bolts to the top and rear of the case where the top link mounts.
After doing my own research, I have decided if I get anything over the smallest backhoe it will be subframe mounted. For safety and not getting that wiggly feeling from the "loose" 3pt connections.
Rich
I just got done reading the L3400 3 point backhoe broke the housing thread. I recently purchased a new L2800, when I picked it up, there was a L3400 sitting there with the same problem- broken casting. I told my dealer that I was putting a Woods 7500 3 point hoe on mine and I was concerned about that but he said it should be fine. I asked about the heavy duty top link bracket and he said they make one for the grand L but not mine. I am afraid to use it now. He is real difficult to get things fixed under warranty. Anyone have any advice? Subframe? Where would I get one at? I bought the hoe used (95 model) and I thought I was getting the proper tractor for it. Should I be concerned? Can you buy a subframe for it? Thanks guys!
I've seen the transmission housing crack. It might even void your warranty. MF states in their price books that 3pt backhoe voids warranty, sub frame required.
Two years ago, I considered buying a TC45D that had cracked the tranny housing because of a 3PH backhoe. Even though it had been repaired, I passed on it - just felt hinky.
So, yes, it DOES happen. Then again, it didnt happen to the previous owner's 1720...
Mark
</font><font color="blue" class="small">( We have all heard the horror stories although I personally have never seen any major damage done because of a 3-point mounted BH. I'm wondering if we should call the "Myth-Busters" to put this thing to rest. )</font>
I have personally seen probably 10 compacts of various colors that either totally split or cracked because of 3pt backhoe use. IT IS NOT A MYTH. And I don't think you can get away with ocassional light use, because when you come up against that one rock, root, etc, you will pull. As an engineer I don't think its so much a matter of fatigue, but rather, just the angle and forces applied. I do know that machines with 3 point backhoes do stretch their case bolts which become loose and this is almost a certain road to failure.
I run a Woods 1050 3pt on my TN75, but that is a very heavy duty Cat 2 setup with extra rigid bracing. All of my compacts over the years, have had subframes. My dealer would not sell me one without.
Andy
And here is a picture Robert in NY posted....... broken bellhousing from a three point backhoe. Unfortunately, there were other pictures lost in past site updates.
   / Need educated on 3 pt backhoe attachments. #17
They must all be liars............... :confused2::confused2::confused2::confused2:
So ar eyou guys saying that ALL 3pt. hoes have to possiblity of breaking the tractor in half or that only 3pt hoes without a subframe have that possibility?
from what I gather from these posts a subframe is tracotr spcific which I pretty much guessed and that MOST ( not all) 3 pt backhoes are universal fit to these subframes. Is this correct?
   / Need educated on 3 pt backhoe attachments. #19
Wow, every single one of those quotes said they ether heard of, someone told them or they read about it.
TBN has got to be the biggest tractor forum on the net. So where are all these tractors ?
If that pic from Robert is truly 3pt BH caused, it only be my second that I've seen and or known of. Far cry from what your making it out to be.
And again, don't take this out of context, a properly done 3pt BH will work, I've got one.
ANY tractor is going to break if you stick something way to big on it, BH or other.
   / Need educated on 3 pt backhoe attachments. #20
Willl, you'd better go to EyeWorld and get some glasses...... then come back and read those posts again. Just because you have a three point backhoe and it hasn't broken your tractor in two doesn't mean it doesn't happen. And what do you mean 'IF' Robert in NY posted a pic of a bellhousing broken by a three point backhoe.............. are you calling him a liar? Use the search function Willl, its your friend.
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2023 Ford Expedition SUV (A59231)
2023 Ford...
