Need good distance guessers (big photo)
   / Need good distance guessers (big photo) #21
I'll say 425' based on a similar dimension on my property. Remember, if you are laying cable, you should allow a few feet extra for going around curves/corners.
   / Need good distance guessers (big photo) #22
It looks like a good poke with a Callaway Big Bertha & it's all carry,
about 245 yards /forums/images/graemlins/cool.gif ...RayBee
Hummm, just thought of something. I have the camera that picture was taken with, If I can find something that is 6 foot wide and take several shots while moving away. When the picture I take has the 6 foot object the same pixel width as the buildings, I should be close to the same distance away..
   / Need good distance guessers (big photo) #24
I noticed utility poles in the picture. They might be a uniform distance apart. Maybe you could contact the utility company for the distance they are set at then count the number of poles.
Good idea but what looks like utility poles are a ski lift and light poles.. I will try the camera today and let everyone know what I come up with.
   / Need good distance guessers (big photo) #26
I just thought of something as well why don't you just step it off and have it over with.
   / Need good distance guessers (big photo) #27
753 feet.
Yes, I really spent some time on that.
Is there a map available of the area, say on TerraServer?
Maps
You could import it and count it off that way....
-Mike Z.
   / Need good distance guessers (big photo) #28
The chances that I actually found it are about .05%, considering I don't know where it really is, but, is this it?
   / Need good distance guessers (big photo) #29
Another thought regarding maps, if it is a ski resort do they have a map that shows the various slopes? You may be able to figure the distance if there is anything to provide scale.
   / Need good distance guessers (big photo) #30
There must be more to this story.
Why exactly do you have to try and figure this out from a picture? Is there a reason you or someone else can't step it off in person? Please explain.
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
Giyi Pallet Forks (A57149)
Giyi Pallet Forks...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
Case IH Maxxum 115 (A57148)
Case IH Maxxum 115...
2013 RPM 30' Flatbed Trailer (A57148)
2013 RPM 30'...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
