NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ?
   / NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ?
westbrooklawn said:
You will get a lot of good advice on tractorbynet, but you might also want to check out this forum Net Tractor Talk - Powered by vBulletin
They have a section totally devoted to Kubota RTV's and they also have some very knowledgeable folks that are very helpful.
Thanks!
If anyone has anymore thoughts for me please up. Im interested in checking the " screen " that has been brought up.
Thanks!:thumbsup:
   / NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ? #13
Thanks!:thumbsup:
I was unable to find info on a hydraulic screen in searches for the RTV 900...somebody with an owner's manual should be able to help you out. Mine is a 500 and I'm not confident we have the same transmission. :confused:
Here is some help maintenance info, it probably won't help you with this particular problem but if you don't have a manual it could come in handy down the road.
Kubota : RTV-Series
Yes, i have googled it over and over and a hundred different ways. I went out there and took bed off so i could get to stuff but i didnt see anything that looked like it had a screen/filter
   / NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ? #15
Do you know if your transmission is a VHT Plus? I have the factory service manual for my 500 I just didn't want to give you the info out of that if it's not accurate because it would just make it more confusing.
How would i know? Its a 2006 model i belive. But im pretty sure its vht
   / NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ? #17
The service manual for the 500 lists 5 possible problems leading to the machine not moving in either direction
1) Oil level low
2)Control linkage or cable defective
3) Charge pressure too low
3.1 Replace oil cartridge
3.2 Check charge pressure
3.3 Inspect of flush charge relief valve
4) Check and high pressure relieve valve does not move smoothly
4.1 Inspect or replace check and high pressure relieve valve
5) Component parts defective
5.1 Replace transmission assembly
Given that you have some movement I would assume a relief valve problem to be the most likely.
1) Oil level low
Where might this valve be around this mess? I cant get it into reverse at all now. It will go into low but feel like its hung up, like its in reverse and low at the same time...
   / NEED HELP PLEASE! KUBOTA RTV 900 BAD TRANNY ? #19
Give me a minute and I'll sent a PM to you with pics:thumbsup:
This thing is junk... Lol
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
Ratchet Straps (A55852)
Ratchet Straps...
2002 Miller Trailblazer 301G Towable Welder Generator (A55851)
2002 Miller...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
