Need help plumbing 2nd loader valve.
/ Need help plumbing 2nd loader valve. #1
milstencil
Berkshire Cty, MA
Kubota B2910HST4WD
A little back ground, tractor is a B2910 with a LA402 loader. I have been frustrated for years at having to remove the loader hoses to use the front mount snow blower and angling grader blade. I would like to be able to use the loader and use the other implements without disabling the loader.
I have acquired a complete loader valve, joystick and hoses for the LA403 loader.
My first question is, can I T-off the main feed which comes from the case to my original valve (photo A) and hook up the main feed of the second valve (photo B) to it?
Second, can I route the returns for the second valve to the "option" (photo C) which are the parts for the rear remote option on my tractor?
And finally if this can be done, will it affect the performance of the hydraulic system? I will not be using any two implements at the same time. It would be nice to be able to pick up a load of gravel and grade it out without having to take of the blade.
Any suggestions would be gratefully appreciated.
Rick
/ Need help plumbing 2nd loader valve. #2
I don't think you can do that.
You need to feed the second valve from the first valve via power a beyond port. I'm pretty sure you have an open system, so if you "T" the pressure side, when you use one of the valves, the hydraulic fluid will just flow through the open center of the other valve. It will find the path of least resistance. The valves need to be hooked up in series ... one after the other.
You can however, "T" the returns from the 2 valves back to wherever they go.
/ Need help plumbing 2nd loader valve. #3
You definitely can not "T" high pressure hydraulic lines. All valves must be in series. Performance of your hydraulics will remain unaffected.
Do a search for "power beyond" for hours of reading on this subject.
Thanks, guys.
I'm off to TBN University for a lesson on "power beyond".
Regards,
Rick
/ Need help plumbing 2nd loader valve. #5
We added a second loader valve to a B7800, which is the same tractor as yours except the premium features. The plumbing is very simple, in fact we have a schematic diagram and pictures of the final set-up. There are pictures of the B7800 tractor with the extra valve on our website at MIE Home Page. We also installed a remote control joystick to the added valve at a later date. The pictures show the valve with handle controls.
You will come off the power beyond of the loader valve, and tee to the loader return for the low pressure return.
Let us know if the schematic and pictures of the B7800 would be helpful to you. I can also walk you though the installation.
This extra valve was used to control the top-n-tilt system we added to the tractor. Works great.
Let me know if we can help.
Michiganiron,
I would like to take you up on the schematic and pictures. It would be a great help!
Now a couple of questions on my valves:
Photo A is my current valve, IN comes from the hydraulic block along with the PB (this is "power beyond"?) and the out returns to the case.
Photo B is the new valve, what are the letter designations P and BY? One must be IN and one power beyond and it looks like the one on the top returns to the case?
To plumb the new valve I would T the PB port (photo A) with which the P or the BY hoses (photo B)? And the OUT? would go back to the case with another T?
Or, am I missing something!
Thanks,
Rick
/ Need help plumbing 2nd loader valve. #7
Rick,
On your first valve, where does the power beyond go to now? To the 3pt valve? If that's the case, then you can put your new valve in between.
On your new 2nd valve, the "P" is where power goes in, "BY" is the power beyond port and "T" is return to tank or sump.
Here's what you can do once you find a suitable place for your 2nd valve.
1) Take the power beyond from your 1st valve and disconnect it from wherever it goes to now.
2) Connect it to the "P" power in on your second valve.
3) Get a hose and connect the PB (power beyond) from your 2nd valve to wherever your 1st valve power beyond USED to connect to.
4) Get a hose and connect the "T" or return to tank port from the 2nd valve to your tank. Or, you can "T" that one to a hose that's already going to tank or sump.
The Kubota guys might have another way to do it, but essentially adding your 2nd valve in series like that will work.
Rob,
You asked: "On your first valve, where does the power beyond go to now?"
In my first post, if you look at the first photo, the PB hose connects to the hydraulic block (drawing #040).
I lucked out when I got this set up, it came with the mounting bracket, which matches 2 of the frame mounting holes for my FEL, and ALL the hoses and joy stick.
So if I'm reading your post right, I will:
1. disconnect the PB hose from original valve
2. connect the P hose from new valve to the original PB port
3. connect "old" PB hose to the new valve PB port and
4. connect the new valves T(ank) hose to a "T" on the old valves T or OUT line.
Correct me if I'm wrong!
Thanks for taking the time to help me out.
Rick
/ Need help plumbing 2nd loader valve. #9
I can send the schematic tommorow if you still need it, but you seem to have the circuit figured properly:
(P) from the tractor block remains attached to the loader valve.
(BY) or (PB) Power Beyond from loader valve to (P) or (IN) of second valve.
(BY) or (PB) Power Beyond of second valve back to the tractor block where the original Power Beyond Connected.
Tee the (R) or (Out) low pressure return to the original loader valve return.
Be sure you new valve not only is Power Beyond capable, but has the power beyond sleeve installed in the (PB) or (BY) port. You need to have the sleeve for the Power Beyond to work.
I'll be back at the shop Monday if you want the schematic.
/ Need help plumbing 2nd loader valve. #10
Yes
Yes
Yes
Yes
Exactly like MichignIron says below.
He makes a good reminder that you need the power beyond sleeve for that new valve for it to work properly too.
The new valve should have a power beyond sleeve that looks something like this one on one of my valves. It should have 2 "O" rings on it and is a threaded sleeve. If it is just a plug, you need to get the sleeve.
-First pic is of valve with plug in the power beyond port.
-Second shows plug on left and power beyond sleeve on right.
-Third shows power beyond sleeve in valve.
Guys,
I want to thank you for sorting out what started out as a confusing project!
Rob, you know your hydraulics, and made it simple for me. The valves seem to have the threaded sleeve, I will check later today.
MI, great web site, I have it book marked, as I still have room for some rear take offs.
Again, thanks for the help, and I will post pix when done.
Rick
As promised, The photo show the PB fitting that is in both of the loader valves.
Is this the correct for what I want to do?
Regards,
Rick
/ Need help plumbing 2nd loader valve. #13
I'm probably wrong, but that doesn't look like a power beyond sleeve to me. It looks like a regular 90 degree elbow fitting. What's inside that port itself where the fluid is blocking the view?
Does it look like this in there?
Don't know if you can tell or not, but the power beyond ports on my valves have 2 channels. They are to allow fluid to go through the sleeve as well as around it. The 2 "O" rings block them off from each other. Look for the one channel on the bottom of the port and then on the sides of the port too.
So I'm sure now I don't know as much as you think I do. I'm stumped now about your power beyond port?
Port does not look like yours. Its threaded down to a shoulder and no openings on the side.
Time to punt?
Rick
/ Need help plumbing 2nd loader valve. #15
Don't punt yet.
If the fitting in the picture is what was in the original loader valve PB port, you are fine. The Kubota LA402 loader is in a power beyond circuit, so the valve was working with power beyond. You don't need to question the original valve PB port or the fitting. It is already providing Power Beyond to the rear of the tractor through the hydraulic block.
If the second valve is the same valve as the original, with the same fitting in the PB port, it should also have PB capability. Not all PB capable valves work the same way with the same type of sleeves.
This may sound like a generalization, but if it is providing PB now, it will with the second valve too. And if the second valve is the same type valve as the original with the same fitting....
/ Need help plumbing 2nd loader valve. #16
Thanks for clarifying that Michigan.
Not knowing th Kubota, I didn't want to suggest that in fear it would not work properly.
However, the Chinese tractors I have do exactly the same thing. They actually use the return (which is under pressure) to feed the next valve, sort of like this one. So yes, it can be plumbed like we talked about then. Keep in mind though, it's always better to power the next valve in line with a true power beyond port. I end up switching the Chinese valves to American and use power beyond on my tractors.
Thanks guys!
Both valves are plumbed with the same fitting.
Original valve is a Husco and new valve has no tags or name stamped on it.
Have to travel to TSC to pick up parts this weekend and will hopefully get what else I need.
Regards,
Rick
/ Need help plumbing 2nd loader valve. #18
Well Rick, we expect the full report when you got it all together and working.
Plus a picture of that big grin on your face showing your satisfaction as a result of having done it yourself.:)
Gentlemen,
The loader valve is finally installed. Sorry for the delay, got involved with another project that took precedence.
I would like to thank you all for the great help! It went smooth as silk after you guys set me straight.
I can now use my grader blade and snow blower without disconnecting the loader, a real PITA. Hardest part was filling the hole on the loader bracket and redrilling so it would match up with holes on the frame.
Again, THANKS!!
Rick
/ Need help plumbing 2nd loader valve. #20
Wow Rick,
That is an extremely clean install you ended up with. It looks great!
I'm very glad you got it all done. So have you tried all the functions out and does everything work alright?
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
