jones6780
- Joined
- Nov 30, 2008
- Messages
- 422
- Location
- Lizella, Ga.
- Tractor
- Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
With no panel lights, it sounds to me as if there is a bad connection or fuse somewhere. Check for corrosion on the battery connections and trace the wires back, both the ground and positive connections. Most positive battery cables go to the starter first. Check the voltage there too. Even if a safety switch was engaged you should still get panel lights.
