Need Help with Cluth Adjusment
   / Need Help with Cluth Adjusment #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have the MF 240 and had to install a clutch.
Before the new clutch we cluld not shift the gears with the tractor running. PTO worked OK.
Now, with the new clutch, the gears work just fine but we cannot turn the PTO on with the tractor running?
Any help would be appreciated.
Wow!
80 views and still no one has any info :(
   / Need Help with Cluth Adjusment #3
Does it now grind when you try to engage the pto?
   / Need Help with Cluth Adjusment #4
Good Afternoon Qapla,
It sounds to me like you have to adjust the PTO clutch, it should be in your operators manual if you have one...
On my tractor there is an access cover on the left side of the clutch housing, remove the cover and adjust three equally spaced bolts with locking nuts so that the head of the bolt gives you a .040 feeler clearance. I would think this would be spelled out in the manual...
   / Need Help with Cluth Adjusment #6
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
John Deere GP Tractor (A50514)
John Deere GP...
