Need help with wires behind the seat?
   / Need help with wires behind the seat?
I bought the Hella Micro FF driving off road lights. I want a lot of light for my driveway this winter... The kits with all components were $61 a piece, I bought 2 kits for front and back. I went to tractor supply and bought some 2" U Bolts (square u bolts) and 2 of the straps they had there (Flat 1/8" bar with holes already in it) they bolt right on the roll bar on the 2520, I just need to trim about 1 1/2" off of both ends. I wanted the lights above me so they weren't in my eyes while plowing.
   / Need help with wires behind the seat? #12
Ha! I forgot that they properly handle links. Good luck!
   / Need help with wires behind the seat? #13
Thanks for the response and details. I am in the process of purchasing and finding what I think is the best solution. Any work light ideas or suggestions would be much appreciated.
   / Need help with wires behind the seat? #14
Oh! I meant to also give you the Amazon link. Here it is:
Amazon.com: SoundOff Signal EWLC1400TBDF0W 5" Rectangular LED 1400 Lumen Flood Light: Automotive
The long link will likely wrap on this bulletin board. Make sure you have the whole link in your browser's address bar or just search for the model number.
Very impressive. Bought to be used as a work light off of the back of a vehicle.
I would say this is way beyond what I thought it would be.
   / Need help with wires behind the seat? #15
That's the light I have as a rear work light on my tractor and I'm very happy with it. The fact it's an LED means it's pretty much impervious to vibration and should last a very long time. The example on the manufacturer's site shows it on a plow truck salting highways at night -- definitely a harsh environment from several standpoints.
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
KBH 25T Tender (A56438)
KBH 25T Tender...
Sterling AT (A56438)
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
