Need some quick advice, IMatch Hitch Deal
   / Need some quick advice, IMatch Hitch Deal #51
Roy, I agree that the applied lifting forces are all provided by the lower arms. The forces around these pins at 18 inches are quite high though. A study of the reaction forces forces would show that alot of weight is transferred to the top link.
Still not the point I was making initially, forty years ago when using cat 1 equipment the lower pins would often wear badly and bend/break, an I Match setup would help alot with this problem as it would allow the top hook to assist with the downward forces on the lower implement pins. Does this make sense to you?
All the top link is doing is limiting the rotational travel of an implement around the lower links...you could use a chain or any other device to prevent that rotation.
It's not bearing weight...just limiting travel.
That's about all the upper hook of a QH is doing too. All the lifting force is still at the lower links.
Visualize this...if you used square links and mating slots (rather then pins and corresponding holes) at the lower links...the square links preventing the implement from rotating...would your tractor lift the implement without an upper link?
   / Need some quick advice, IMatch Hitch Deal #52
I have a gently used cat 1 I-Match QH that I would sell for $200.00 if anyone is interested . It wont fit my 5103 deere. Shipping my be alot though. Bull
   / Need some quick advice, IMatch Hitch Deal #53
Id like to say that maybe the best word for the top hooks function is to HOLD the implement, It dosent lift , it holds the Implement, Hey what ever works for you, is all that matters, :thumbsup: Eric
   / Need some quick advice, IMatch Hitch Deal #54
Yeah, that's about it...
   / Need some quick advice, IMatch Hitch Deal #55
You could also say the bottom hooks lift the front of the implement, and the top hook lifts the rear.
Bruce
   / Need some quick advice, IMatch Hitch Deal #56
Bruce
What powers that upper hook?
Put it like this...remove all implements, including the QH. Then raise the 3PH...what moves up?
   / Need some quick advice, IMatch Hitch Deal #57
Hook up the 2 lower pins only and lift the hitch.
What part of the implement doesn't lift?
Bruce
   / Need some quick advice, IMatch Hitch Deal #58
Roy,
It is all in the moments or forces about the lower pins. In the previous post I agreed with you that the lower arms are providing the lifting forces. That said if I leave my rockshaft alone and shorten my hyd. top link it will raise the rear of the implement.
I understand what you are saying about a square rod connection as opposed to a pin connection but you would also loose the parallegram configuration too.
Black and Tan,
So far has the best analogy and understands what I meant about the quick hitch limiting the lower pin damage. Anything I buy that has alot of weight to deal with I am trying to get with the clevis hitch pin set up, the pins last much longer imo.
   / Need some quick advice, IMatch Hitch Deal #59
Bruce
The aft end, of course...
   / Need some quick advice, IMatch Hitch Deal #60
I just bought a quick hitch w/ adjustable top hook from Iowa Farm Equipment. $249, free shipping, no tax and got it the next day. It's USA made, came with a set of bushings and is black in color. I liked the idea of adjustable if I were to rent something or buy a non compatible implement. It was supposed to come with a "floating top link" for implements on which the the hook would not work. It did not and I've emailed the company to check on that.
That being said, I am fairly unfamiliar with quick hitches. I have not actually looked at an i-match but I know they wanted $300+. I've had my BH on so I didn't have the 3 pt. on until last week. Trying to mount a loaded ballast box is a PITA, especially with a bad back. I also just bought a box blade and may need to switch between the two fairly regularly. It didn't take long to realize the value of the QH!
So... I mounted the QH today and bolted the top hook where I thought it should be. It seemed to mate ok with the box blade but even w/ the 3 pt. at the lowest position the top hook was just a bit high and seemed to carry the weight on the hook. If I adjusted the top link it would just clear the implement center bushing.
I then lowered the top hook and that solved the problem, able to back up and mount easily. The one thing I was concerned about was that top hook was about 3/4" or so lower than the box blade top center bushing. All weight on the bottom. Now after reading this thread, sounds like no big deal. That's kind of what I thought after looking at the design of the 3 pt hitch, the bottom carries/lifts the weight, top link is more of a stabilizer. Does this situation sound normal with an adjustable top hook QH? Seems pretty well made to me.
Thanks,
Steve
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
