Need to know. Mig/Tig vs stick
   / Need to know. Mig/Tig vs stick #11
My kingdom for a class i could take on welding... the stars never align for me.
   / Need to know. Mig/Tig vs stick #12
Certainly not that I am adverse to learning, but I just can't 'handle' classroom atmospheres of any type.
Probably something to do with my being a high school dropout...
Terry
   / Need to know. Mig/Tig vs stick #13
So why TIG for naval nuclear pipe? Because it is slower and more precise? Something in the TIG process that makes it better?
So, how do you wel a 4" thick piece of pipe? Just layers upon layers? How long does this process take?
The 3-1/2" wall thickness I welded on was 32" O.D.,low pressure side of a turbine in a power house.
One pass of TIG(consumable insert) and(3/32-5/16") 9018 LH out.Four welders on 12 hour shifts and if I remember right about 3 days.X-Ray at the start of each shift.
Passes could be no wider than twice the rod size.Lots and lots of passes.Pre-heated also.
   / Need to know. Mig/Tig vs stick #14
I just don't have the patience.
   / Need to know. Mig/Tig vs stick #16
Last time I did any stainless steel Mig welding was in the 1970s. We used a tri mix gas. Far as penetration, I really don't know. If doing pretty much flat welding you can get into spray arc transfer welding.
https://www.millerwelds.com/resources/weld-setting-calculators/mig-solid-core-welding-calculator
Selecting a shielding gas for joining stainless steel - TheFabricator.com
I understand SA has about 3 weeks maybe experience now so take his words with a grain of salt. :D
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
BOX BLADE (A58214)
BOX BLADE (A58214)
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2024 JCB 35Z (A60462)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
