sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,817
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
You guys that want to blow away Fido at first blush are missing a couple things. First, it probably leaves you open to civil action unless you can prove your side of the story. No paper trail, dubious story. Second, the dog owner is not likely to remain calm and thoroughly grasp your actions as justifiable. There is likely to be a reaction on his side and it may be unpleasant UNLESS you followed a logical path before action. I mean, how would YOU react if someone shot your dog without an adequate discussion of the facts?
As I mentioned in an earlier post, the first point is to discuss the issue with the dog owner. Make your points pleasant but clear and unyielding. It's his problem, not yours and he needs to fix it. You need to explain that he must take action to fix the problem so the dog warden doesn't have to get involved. Remember, pleasant but unyielding. Most people will respond to this approach.
If he does not respond to this I would call and say you really don't want to but have to get the animal control people involved. Then do it and copy the police dept. In almost every case this will fix the problem.
If it doesn't, call or write both animal control and the PD and tell them about whatever action it is that makes you feel threatened. Ask them what you should do if attacked on your property--if that's the concern--or how to stop the poo problem that your little grandchildren are getting into. They will tell you what to do.
After this, or if attacked along the way you have at least some degree of justification and are far less likely to provoke a retaliatory action by the neighbor. Just my two cents here--I don't have a dog in this fight.
