New 2520 brought home tonight!
   / New 2520 brought home tonight!
Hey, thanks for the info. I'll try to adjust the clutch tomorrow.
The turn buckles are really a pain though. I have to readjust the Left side about every hour. AUGH!!!!!!!!! Any solutions?????
   / New 2520 brought home tonight! #33
Is there a hole in the end of the threaded rod that goes into the turnbuckle? There is on mine, and I have some pins in the hole--pretty big ones so that the turnbuckle can't rotate around--it can go about 1/4 turn and then hits on the pin. They originally had a "split" ring in them--but they were a pain to remove so that you could adjust the turnbuckle.
   / New 2520 brought home tonight! #34
I was thinking of putting bolts in the holes, but pins would work better I'd think. The split ring was bent to the point of being useless. The turnbuckle kept turning and bent the ring so that I had to cut it off.
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
8ft Fork Extensions (A50322)
8ft Fork...
