New 2520 brought home tonight!
   / New 2520 brought home tonight!
Hey, thanks for the info. I'll try to adjust the clutch tomorrow.
The turn buckles are really a pain though. I have to readjust the Left side about every hour. AUGH!!!!!!!!! Any solutions?????
   / New 2520 brought home tonight! #33
Is there a hole in the end of the threaded rod that goes into the turnbuckle? There is on mine, and I have some pins in the hole--pretty big ones so that the turnbuckle can't rotate around--it can go about 1/4 turn and then hits on the pin. They originally had a "split" ring in them--but they were a pain to remove so that you could adjust the turnbuckle.
   / New 2520 brought home tonight! #34
I was thinking of putting bolts in the holes, but pins would work better I'd think. The split ring was bent to the point of being useless. The turnbuckle kept turning and bent the ring so that I had to cut it off.
20' Sea Container (A50774)
20' Sea Container...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Kubota RTV1100 Utility Cart (RUNS) (A50774)
Kubota RTV1100...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2009 Dodge Ram Utility Pickup Truck, VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
