NEW 2610!
   / NEW 2610! #21
Hmm, Mine does not have this rubber insert either and its a 2008. I've lost 4 bolts that tensions the rops. They always tend to rattle loose and out. I need to get some more but this time I'll double up on the nuts to lock them in. I'll look into these rubber pieces.
   / NEW 2610! #22
Just drill a hole at the start of the threads of the bolt and insert a cotter pin or a set pin (after bolt is installed)... This way it can only loosen so far before the pin stops it from going any farther and falling out. Or a real easy way... After installing the bolt, just take a center punch and hit the last few threads, that should be all that is needed to stop the bolt from coming out "easily".
   / NEW 2610!
On my old 2310 I used rubber garden hose gaskets on the ROPS bolts to quiet the rattle. It worked pretty good.
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
HIGH END MINI GOLF CART (A58216)
HIGH END MINI GOLF...
HAY SPEAR, 3PT (A58374)
HAY SPEAR, 3PT...
2005 John Deere 200C LC (A55272)
2005 John Deere...
