New Attachment
/ New Attachment #1
NHbotanut
Central NH
Kubota B7610HSD
Picked up a Land Plane ( Grading Scraper ) last weekend to help maintain the driveway.
I will also use it to to level the lawn as I am starting
/ New Attachment #2
Good for you, I would recommend you get used to the landplane smoothing the lawn area first if possible. Much easier place to learn the ropes and correct the divots. A little trial and error and you can quickly get the hang of adjusting the top link to get good results.
/ New Attachment
Sorry I didn't get pics up sooner. Been out of town.
It was nice to finally have a smooth driveway again. Looking forward to getting the lawn all smoothed out once all the planning is down for the irrigation system.
/ New Attachment #5
I do alot of this type work, I recommend you smooth the lawn area first to get a better idea of the height to set the sprinkler heads. You can smooth it out again after the irrigation system is installed.
I would also suggest you make sure the heads are low enough you can drive over them without damage. I use the Hunter PGP series gear drive units and have installed the 12 inch pop ups for one of my customers with great success, I have these retracting below the surface about 3 inches. Makes maintaining the lawn much easier without fear of damaging the heads.
/ New Attachment #6
It looks like your new toy is doing a great. They do make a huge difference on a gravel driveway. Here's a video of us trying one out on a driveway that hadn't been maintained in over 5 years.
[ame=http://www.youtube.com/watch?v=OIed2lzfQ-g&feature=plcp]How To - Tractor Land Plane - Gravel Road Maintenance - YouTube[/ame]
/ New Attachment #7
Good video! :thumbsup:
/ New Attachment #8
What I've found is, like Ted's video, you can run 'em without the teeth down first to see what it will pull up... I've used mine on some sorry looking drives and you'd be amazed how much gravel it will float to the top of the surface! Won't end up looking "just like new", but it will sure be a sight better than what you started with. If you've got bad ruts, then you can run the teeth down after a pass or two if the blades are enough to get it the way you want.
I really like watching mine work, the gravel spilling over the blades is kinda hypnotic. Just be careful that you don't run out into the road watching it... :eek:
/ New Attachment #9
Congrats!
I am wondering how much you will use the rippers? It seems like most of land planes do not come with rippers...
/ New Attachment
I do not think I will use the rippers very much, if at all. But it is nice to have them if needed.
I was very surprised at how much material it brought up to the surface after just 3-4 adjustments to the top link.
/ New Attachment #11
looks like you could have afforded to go wider. On something like that i think you could go 7+ feet wide to grade more of the drive at one time. You should have plenty of tractor to pull even that wide.
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2007 PETERBILT FLAT TOP SLEEPER  385 (A67714)
2007 PETERBILT...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
2018 BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
2018 BRADLEY...
213087 (A64276)
213087 (A64276)
