New AutoHST
   / New AutoHST #21
This Is An April Fools Joke! It Has To Be Isn't It? If some idiot can't grasp Twin Toe Pedals ON a Deere Tractor, then they shouldn't be near tractors at all..... Now The Auto Throttle I can see, Like Kubota Has, but this is just retarded!
   / New AutoHST #22
Who came up with this crap? I predict it will go away soon - probably won't last a year.
D.
   / New AutoHST #24
I truly don't get it. A combo of power reverser and a e-hyrdro? The brake is on the right - correct? Above the HST pedal?
I like the brakes on the opposite side - no confusing where it is.
I tried that skateboard thingy on the kubota - I'll pass.
As far as putting the machine in neutral - you can do that with the selector, but the machine might roll. Just take your foot off and put on the parking brake.
Somebody clarify this new setup for me. I might have to go drive one just to see it.
D.
   / New AutoHST #25
gamble77 said:
Below is the press-release from Deere on their new AutoHST system for the 35/3720, I have also attached a few pics. from the article...
AutoHST - New transmission option for 3520 and 3720 Compact Utility Tractors
Why screw up a pretty much perfect design?
AutoHST is designed to resemble an automotive-type control system. When the operator sits in the seat, he or she will feel right at home; the controls resemble those of a car.
Automotive-like features:
Lever on the left for Drive-Neutral-Reverse to engage the transmission
Single "go pedal" on the right to go forward or backward
Single brake on the right, like the brake in a car
Beyond this simple layout, AutoHST has all of the features that eHydro provides such
Last time I checked, the brakes in a car were on the left - not above the gas pedal.
D.
   / New AutoHST #26
Well, my 955 had a single brake pedal above the go pedals on the right,
and a dual brake pedal on the left. It met the needs of someone wanting
to use the right foot, as well as separate braking with the left foot. Does
the AutoHST have brakes on both sides?
What I do not get is why Kubota has stuck with the foot pedal dry clutch for
their HST-Plus tractors. Why not use an electro-hydraulic PTO clutch like JD?
Keeping that clutch pedal keeps them from putting the dual brakes on the
left and I know of a chain of rental yard that won't consider Kubota since
renters ruin tractors with foot clutches. I see that Kubota has a new
compromise brake dual-pedal system on the Grand L40s where the pedals
are just right of center, left of the go-pedal.
   / New AutoHST #27
Kubota has had electro-hydraulic clutches on the L's since the 10-series from the late 90's. There is still a main clutch to ease starting, and so you can feather PTO attachments up to speed if you want. They really could remove the cluch completly, but there are some applications where you still want it. The PTO clutch is hydraulic.
I know guys here fuss about turning brakes, but your average customer knows nothing about it, would never use them, and will be none the wiser.
   / New AutoHST #28
How does a foot clutch ease starting? We are talking HST tractors here,
not GSTs or FSTs.
For what applications do you still want a foot clutch on an HST tractor?
Although I find the centered brake pedals an improvement on the Lxx40s,
JD is a clear winner over Kubota, Kioti, and others when it comes to foot
brake placement on many of their tractors.
   / New AutoHST #29
not GSTs or FSTs.
Ditto! All the pedals on the right side of the Kubota sent me straight into the Deere dealership.:D
   / New AutoHST #30
Cold weather starting is one, a main cluch can disengauge the transmission and takes that load off the engine. Your spinning the hydro-pumps even when the tractor is not moving. I personaly prefer a cluch over a switch for operating some implements. A post hole digger is the first thing that comes to mind, I just find it easier to operate with a foot cluch than a switch. Implements like chippers are better featered up to speed than suddenly snapped on. Its really an amount of personal preference, there is no dire need for a clutch and year after year its offered on less models. So I'm probably the exception.
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
207270 (A52708)
207270 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2003 International 9200I (A53317)
2003 International...
