New BX On the way next week!
   / New BX On the way next week!
AFChief - I apologize for mentioning the Bro-Tek skid plate(s) without giving you ordering advice. Richard's website isn't the easiest to order from but he makes a top notch product. Go to Feedback and enter your name, email address and what you want to order. He will email you back and give you instructions on how to pay with paypal. No worries, he's good people.
As for leonz comments about the injection pump timing, I think he got the BX confused with the B3200. No vibration issues with any BX's that I've heard of or experienced myself. It is a little rough at idle but it's normal. If it bothers you, just bump up the throttle a little and it goes away.
Thanks for your service! I currently work for the Air Force as a government employee and US Army retired.
No worries. I got the info emailed to me this evening....:thumbsup:
   / New BX On the way next week! #32
The EPA has mandated lower emmisions for small diesels and the vibration problem does exist and the small engines timing has been advanced in the small TRACTORS but the engines are used in other applications and have not been messed with.
then again- how to do it? remember some of us newbies want to learn:thumbsup:
Also does removing the advanced timing help the fuel or use more?
will it provide a bit more oomph? or lose HP?
will it make it scream less at higher rpms?
etc etc. I look forward to your rebuttal comments leonz.:D
   / New BX On the way next week! #33
With the timing reset to Zero degrees T.D.C. It will use a tiny bit more of
diesel fuel at the feed bunk but the power will be fine and the vibration issue
at low idle will be gone and you will be able to start it at idle with no smoke
and the banging that goes along with it.
Nor you will not lose horse power and the power delivered will be balanced.
The low idle will be normal and the engine wil just purr at idle like it is
supposed to (even when cold).
The engine will make less noise as the timing will be at the proper zero
degrees.
You need the work shop manual for the engine model and the tools required
to do the job and it will be back to normal the way it should be.
   / New BX On the way next week! #34
Where are you coming up with the 0 tdc number? That is not the kubota spec. Looking back at over 20 years of specs I can not find that it was ever 0 tdc. Please explain!!!
Well dang. Trctor delivery has to wait out this weather...Catch 22. Can't get it because of the weather, but need it, because of the weather......
After numerous delays from the weather, it's finally here! Some drama because of the cold, but fianlly got her in the shop and got the belly mower off for some serious snow removal OJT tomorrow.
Obligatory pic...
   / New BX On the way next week! #37
Congratulations on your new arrival; good times to come.:thumbsup:
   / New BX On the way next week! #39
Congrats on the new machine. :thumbsup::thumbsup:
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
1969 Lincoln Continental Mark III Coupe Collectible Car (A51694)
1969 Lincoln...
UNUSED Black Metal Roof Panels (A53117)
UNUSED Black Metal...
