New Farmall 100
   / New Farmall 100
Sorry I am having trouble. Self taught computer skills not as good as they could be. /forums/images/graemlins/confused.gif
   / New Farmall 100 #13
Cool!
Have you tried hand cranking it yet? It is always fun seeing peoples reaction when you get the handle out and fire it up!
   / New Farmall 100 #14
Looks very nice, complete, good rubber....... now you have to get a sound clip out there so we can hit her run! ;-)
   / New Farmall 100 #15
I don't have a crank for my 130, and the hole through the front is obstructed by the tin on the front, were the 130's not meant to be cranked? Somehow I suspect with the 'high' compression ratio (6.7:1 I think) and the oversize pistons and sleeves used for the rebuild (so I don't know what the actual ratio or displacement is) it would probably be pretty hard to hand crank. The 6V starter certainly has its work cut out for it.
- Patrick
   / New Farmall 100 #16
Wow, seeing that beauty brings a tear to my eye. Brother to my Farmall 100. What serial number is yours by the way, my serial is 1666 which apparently is a 1954. It would be cool if they were the same year of production.
I am looking to find a handcrank, just to try it out for fun. There is a salvage yard here in NC that says that have some.
So is your a 6v or 12v conversion?
Ramon
   / New Farmall 100 #17
Hey, I noticed that you had a Sickle Bar mower mounted at the same time as the Fast Hitch. Can the Fast Hitch operate normally with the Sickle bar mower mounted? On mine I have an additional arm running from the front of the FH Bar to the right front hydraulic rockshaft which I don't see on your tractor. I am curious because I would like to get a sickle bar mower for cutting hay but my first option was trying to find a Fast Hitch Sickly Bar mower.
Ramon
   / New Farmall 100
I'll get some close- up pictures of the sickle bar set- up if it ever stops raining around here. The Fast Hitch appears to work, but to be honest I haven't paid much attention and the last time I drove the tractor the sickle bar was off.
   / New Farmall 100
Need to get a hand crank, just in case, you just never know. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2024 John Deere 6110M (A50120)
2024 John Deere...
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
Kubota B7200 (A50120)
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
Volvo 9.5 Cu Yd Hydraulic Loader Bucket (A50322)
Volvo 9.5 Cu Yd...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50322)
2016 Hurricane...
