New Farmall 100
   / New Farmall 100
Sorry I am having trouble. Self taught computer skills not as good as they could be. /forums/images/graemlins/confused.gif
   / New Farmall 100 #13
Cool!
Have you tried hand cranking it yet? It is always fun seeing peoples reaction when you get the handle out and fire it up!
   / New Farmall 100 #14
Looks very nice, complete, good rubber....... now you have to get a sound clip out there so we can hit her run! ;-)
   / New Farmall 100 #15
I don't have a crank for my 130, and the hole through the front is obstructed by the tin on the front, were the 130's not meant to be cranked? Somehow I suspect with the 'high' compression ratio (6.7:1 I think) and the oversize pistons and sleeves used for the rebuild (so I don't know what the actual ratio or displacement is) it would probably be pretty hard to hand crank. The 6V starter certainly has its work cut out for it.
- Patrick
   / New Farmall 100 #16
Wow, seeing that beauty brings a tear to my eye. Brother to my Farmall 100. What serial number is yours by the way, my serial is 1666 which apparently is a 1954. It would be cool if they were the same year of production.
I am looking to find a handcrank, just to try it out for fun. There is a salvage yard here in NC that says that have some.
So is your a 6v or 12v conversion?
Ramon
   / New Farmall 100 #17
Hey, I noticed that you had a Sickle Bar mower mounted at the same time as the Fast Hitch. Can the Fast Hitch operate normally with the Sickle bar mower mounted? On mine I have an additional arm running from the front of the FH Bar to the right front hydraulic rockshaft which I don't see on your tractor. I am curious because I would like to get a sickle bar mower for cutting hay but my first option was trying to find a Fast Hitch Sickly Bar mower.
Ramon
   / New Farmall 100
I'll get some close- up pictures of the sickle bar set- up if it ever stops raining around here. The Fast Hitch appears to work, but to be honest I haven't paid much attention and the last time I drove the tractor the sickle bar was off.
   / New Farmall 100
Need to get a hand crank, just in case, you just never know. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2024 KMC 7406 (A53084)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
2020 John Deere 260E 26 Ton Articulating Off-Road T/A Dump Truck (A50322)
2020 John Deere...
