New grapple is loose. Need help.
   / New grapple is loose. Need help. #31
I prefer his method, using 1/2" stock. If he had remodeled the shims he would only have a 3/16" edge against the pins. With his method he'll never "wear" them loose again.
   / New grapple is loose. Need help. #32
,,,,,,,,No:
... Weld thru the slot from the bottom side to the part of the shim that overhangs the slot. Build it up enuf for a good sturdy surface for the pin to bear against.
larry
,,,,,,,Yes. Bolded for clarity in the descriptive I provided on request below:
I had considered this method and the idea was helpful but as you said, it would have required building up the weld and then grinding it back to fit the space, at the correct angle to get the pin's angle to match it correctly. Using the 1-2" bar I didn't have to grind anything and it fits perfectly.
Thanks again for the idea.
   / New grapple is loose. Need help. #35
Well stated.
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Toro Sand Pro (A56859)
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
