New guy: Ford 3000 questions
   / New guy: Ford 3000 questions #11
You could probably find a shop to do it for 1200-1500 if you look. Its the labor that gets you.
Ok, thanks for the information.
My deal is that I keep the tractor 150miles away at a country property so it's not sitting in my garage to work on. Plus I can't bring it home as I don't have anywhere to put it.
   / New guy: Ford 3000 questions #13
try the adjustment on the clutch freeplay first and see what ya get.
soundguy
   / New guy: Ford 3000 questions #14
I've never posted here before so I hope I don't screw this up. I haven't been around the Ford's for many years, but doesn't the 2 stage clutch tractor's have a pin on the clutch rod with two holes in it. One position is for transmisson only and the other position is when you want to use the Pto. In this setting the cluch sets a lot higher, and work's the Pto. At least the 860, 861 ect. worked this way. Worth a look, correct me if I'm wrong.
Well, I didn't have an opportunity to fire up the old tractor but I did get to see her for a minute. I found out that I can easily lift up the clutch pedal about 2 inches from where gravity rests it. Is this the freeplay range?
   / New guy: Ford 3000 questions #16
no.. freeplay is where you push before you feel resistance.
   / New guy: Ford 3000 questions #17
I got 3000 ford, gas, 8 speed. The problem I have I cannot engage the PTO with clutch pedal all the way to the floor while engine is idling. If I stop the engine, the PTO level will engage the PTO shaft, i can crank the engine and the PTO shaft turns over the brush hog blades. so, do I have a problem with the 2-stage clutch, is plate "frozen?"
   / New guy: Ford 3000 questions #18
could be stuck or way out of adjustment.. or past it's service life.
have you set pedal freeplay?
Z Spray Ride On Fertilizer Spreader (A57149)
Z Spray Ride On...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
LOT: Assorted Pry Bars & Punches (A59076)
LOT: Assorted Pry...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
