ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Nor I. I suggested running a hot wire to the switch to prove connectivity between power and switch.I wasn't suggesting hot wiring around the fuse except "very briefly" as a trouble shooting tool. Check your fuse panel and make sure someone hasn't jumper the fuel shutoff fuse(5 amp). If this or any fuse in panel has been jumped then the master fuse is next in line.
I'm with Eddie, hoping the replacement fuse link fixes the problem.
