New Holland Reliability Record
   / New Holland Reliability Record
Thanks for the advice, but how do I go about checking if the hours have been tampered with if the tractor has been in the possession of the dealership for the last two years ? In other words, it would have been the dealer that adjusted the hours if their low so there's no point in asking the Dealer. Is there some way I can check the hours myself or is it best left to a mechanic ?
   / New Holland Reliability Record #12
Does Canada require a registration and title for tractors? If so state records or reporting bureaus would be a good start. If this isnt the case then youd need to find the previous owner and hope he has a good memory.
   / New Holland Reliability Record #13
Looks like I'm going to be the one dissenting voice on this. I think for a 3 year old tractor, that has been pretty much stored outside, $17,500 is too high. My guess is that tractor was somewhere around $20 new, so that's not enough of an incentive for me after this long. I'm not in favor of Supersteer, so maybe I'm even more biased. Why not compare to a comparable new model with exactly what you want. Then you'll know what your saving. If it was me, I'd prefer a 40D or DA without the supersteer, instead spending the extra on the added HP. But, if you've got a lot of really tight corners to work in, maybe it's worth it. I've never yet found a spot where I needed it however as the non-supersteer versions turn pretty sharply already. Good Luck!
2020 Bobcat T595 Compact Track Loader Skid Steer (A51691)
2020 Bobcat T595...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51691)
2017 Mack GU713...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Used 20' Container Box (A52384)
Used 20' Container...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
