New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)?
   / New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Very esoteric question.
Does New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)??? I have a NH dealer who gets his hydraulic fluid from US Oil. The dealer tells me that the THP (name of fluid) is the same as the NH hydraulic fluid spec Multi-G 134 Fluid (NH-410B). The sales rep at US Oil sent me a note saying they are the same spec.
I ask here, since the world of hydraulic fluid equivalencies is so complex and mind-boggling. My goal is to change the 11 gallons of hydraulic fluid on my TN 70A. I just want to do no harm.
Any help would of course be appreciated.
Bob
The answer is..........................
Multi-G 134 Fluid (NH-410B) has a New Holland Spec of M2C134D. It is
what should be used in an TN70A hydraulic system!!!!!!!!!!!!!!!!!!!!!!!
   / New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)? #3
Bob, I'm certainly no expert in this area, but to me Multi-G seems to imply multi-grade (multi-viscosity), sort of like what the MC200 fluid was supposed to be. The old Ford (and then New Holland) M2C134 was defineately not multi-grade and I thought that is why they came out with the all-weather 200 version. I'm still confused!
I agree with being confused, I am confused :confused: . I have researched this issue until I am "blue" (pun intended) in the face.
Dealer agrees with manufacturer who agrees with NH. I will try to scan and post what i have tonight and let everyone read what I have. maybe a few more eyes will help.
Bob
PS Do you have a source for M2C134 not being multigrade that I can review?
   / New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)? #5
What's important is M2C134D specification. It's sort of like 10W40 motor oil. It doesnt' matter if it's Valvoline or Mobile, it's supposed to work the same.
I use Valvoline Premium UTF mainly because I can get it at my local NAPA versus 25 miles to the closest NH dealer. Take a look at the attached PDF. Check out the section about 1/3 down the page where it tells what manufacturers specs this UTF meets.
  • Valvoline Premium Universal Tractor Fluid.pdf
Thanks!
Bob
   / New Holland Spec M2C134 =Multi-G 134 Fluid (NH-410B)? #7
Bob
Cenex Qwiklift HTB Tractor Hydraulic Fluid is recommended when the following manufacturers, specifications, or performance levels are called for: Ford/New Holland: Ambra Multi-G 134 Fluid (MAT 3525, NH 410B),
Ambra MasterTran (MAT 3505, NH-410C), FNHA-2-C-200/201.00, ESN-M2C134-D, M2C41B, M2C48B/C, M2C53A/B, M2C86B, M2C159B/C
Tractor Hydraulic Fluid - Cross References available at ourcoop.com/productcatalog/Main/PdfViewer.aspx?el=86986 NOTE: Type www in front of ourcoop. This blog will not let me post a link since this is my 1st post.
  • Tractor Hydraulic Fluid - Cross References.pdf
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
John Deere 5055E (A53317)
John Deere 5055E...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
