New Home Begins
   / New Home Begins #131
As the OP, and having done a lot of research before committing to the Superior Walls, I can add what I learned. I too was skeptical about a crushed stone footing. What I learned is that the weight is distributed outward at an approximate 45 degree angle from the direct point load of the wall. This means that a 10" thick wall section will bear on a 18" base for a 4" thick base (4" exterior + 10" wall + 4" interior). An 8" thick crushed stone footing will distribute the weight over 8 + 10 + 8 = 26" wide. Superior provides charts for the thickness of the stone base based on expected loads.
The stone used is 3/8" clean crushed stone and is mechanically compacted (twice in one direction and twice in the opposite direction) to lock in the stone. Adjustments are made to reset the proper elevation after compaction.
The walls are then directly placed on the stone, bolted together, checked for plumb and level, repeat.
One claimed benefit of this process is that there is less hydrostatic pressure against the wall from ground water as the water can naturally flow through the footing and be picked up by your french drain.
The reasons I am using a poured footing instead of the stone (at least for the house itself, the garage will use the stone method) are two-fold: 1) The soil composition and it's load bearing ability, given the higher water table, was unknown during the design phase and the architect was not comfortable with the unknown and the ability of the gravel to NOT sink down further and 2) if there is a failure due to settling of the gravel, then the result can be water infiltration into the house.
One downside of the footing is that I now will have a french drain on the outside, carry the water through the footing to the interior only to pump it outside again.
I'm sure Superior must feel confident about that. I think your arch. made a good choice on your behalf though, given the unknowns about the soil bearing quality. The french drain effectiveness thing is maybe a wash since the drain would, if done correctly, be below the bottom of the wall either way.
It isn't unusual to bring all the water from foundation drains and downspouts into the basement, and then back out when hooking-up to a sewer line, although it doesn't seem logical really.
   / New Home Begins
Can't do that here. It's illegal to hook your sump to the sewer. Of course, I am on a septic system, but why add that additional water to the tank and field?
   / New Home Begins #133
Ah. I assumed city sewer. Where would you send your sump water if not into a sewer, if you were on one? I guess some areas are developing separate storm drains to prevent flooding treatment plants which results in raw sewage going out.
Well, that's the great septic system debate. Everybody says it's stupid but you are supposed to do that in some places. You might consider an outdoor sump pit rather than bring it back inside-if that's allowed. That would keep the french drain water outside and it shouldn't freeze in your location if you get it down in the ground a bit. You could also route your gutters to that pit, at least for part of the roof area.
   / New Home Begins #134
Interesting project, could you bring the water to daylight at a low area on your property. I have heard of so many horror stories about power outages or pump failures, and flooded basements. Be sure to use a sealed sump pit in the home, inlaws built a retirement home in the country 12 years ago, and have mold on the block walls, do to the added moisture from an open pit. There is also the risk of radon gas. Also do not run to a septic, there pump did and the sewer backed up, do to a wet spring.
Dave
   / New Home Begins
The basement will have two separate sumps on diagonal corners. We are still figuring our options for run off containment. There is a natural stream (dry usually) that I can run it to but that is 200' away, so not the best option. Longer term option is to possibly put in a cistern to collect runoff and sump and use it for gardens/landscaping. But that is 2 years out, so we need to come up with something that is not completely a throw away interim solution.
   / New Home Begins #136
I like the cistern idea, you will need alot of water for your new yard and landscaping. Maybe a large plastic water tank for the now.
Dave
   / New Home Begins #137
Generally bearing loads on to footings from a traditional house are extremely light and actually don't require a spread footing in most cases depending on soil types. You are better off increasing the bearing loads onto soils that have expansive characteristics and often in those areas a footer is deliberately omitted from even large building designs.
   / New Home Begins #138
Tom, If I'm not mistaken I believe the concrete floor has to be poured before you can back fill so as not to move the walls but I'm sure you/your builder know that. Also wondering have you had any contact with the neighbor regarding the fence and trees? Keep the pictures coming and continued good luck to you. Stanley
   / New Home Begins #139
Maybe you could put in the beginnings of a water garden now, and finish it later. If there is a an area between the house and the stream bed, a water garden somewhere in-between would allow you to move water from the house, through the water garden with an outflow to the stream.
At this point--and it will never be easier, and without spending much, getting the pipes from the french drain and gutters tied together and run to the water garden location might be enough to get the water away from the house for a couple years. I assume you have some natural fall in the grade toward the stream. A rented trenching machine should handle the pipe install.
Of course, it helps if you like water gardens :laughing:
   / New Home Begins #140
Most communities I serve suffer from sewage treatment capacity. There can easily be 10 times as much water entering the sewage system from sump pumps as compared to actual wastewater. Larger communities have homeowners tie into nearby stormsewer pipes if available. Otherwise it is pumped outside and verified by the Sheriff if need be.
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
2017 PJ TRAILER 20' T/A TRAILER (A58216)
2017 PJ TRAILER...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2013 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC2KZCGXDZ156404 (A57453)
2013 Chevrolet...
2211 (A58376)
2211 (A58376)
