New iMatch AutoHitch
   / New iMatch AutoHitch #2
I guess it's some thing else to put on our "wish list" :D
   / New iMatch AutoHitch #3
double wow:cool: :cool: :cool:
From the build & price
$385 for tractor side + $244 Imatch (can be retrofitted to exisitIng IMatch) + $165 - $270 for each attachment - so far rotary cutters & tillers.
   / New iMatch AutoHitch #4
That's slick. Pretty pricey, but slick. The tractor side isn't bad at all, but $165-270 per implement is what would kill you. ;O)
   / New iMatch AutoHitch #5
I'd buy that for my MX6 in a second. Where do I sign?
   / New iMatch AutoHitch #6
I ask my dealer about this. and thay said it never came to pass. there was a problem with it. i wanted one. :( and though it was on the website. deere never shipped them out. and he thought the project was going to be scraped. I guess we will see.
Chris....:)
   / New iMatch AutoHitch #8
Chris....:)
Then neither you nor your dealer watched RFDTV last night (6/18/07) with the Live John Deere hour. That was one of the new products featured on the program.
   / New iMatch AutoHitch #9
Looks like the new PTO connector (autohitch), for the moment, only works with certain CUT tractors. They have a compatability chart, and I was surprised to see that the 5000 series are not currently (doesn't mean they won't ever be) compatable. I think even the 990 was not currently comptatble. A quote from their FAQ on the autohitch:
Does iMatch AutoHitch work on 5000 Series tractors?
While a 5000 Series tractor can be set up to work with Category 1 implements, John Deere has not tested the AutoHitch on 5000 Series tractors; therefore, they are not currently compatible.
the link on currently compatable tractors, if I did it right:http://dlrdoc.deere.com/sales/salesmanual/en_NA/material_handling/2007/compatibility_supplemental_info/tractor-implement_compat_ah.html
Edit: and here is the link for an overview of the imatch autohitch:
http://dlrdoc.deere.com/sales/salesmanual/en_NA/material_handling/2007/model/cuts/imatch_autohitch.html
Good luck, I sure was disappointed when the 5103 wasn't (yet) covered. Their web site has some cool explanation of how it works, as well, and check out the demo of loading/unloading 2 impliments in 1.05 minutes. Amazing. But, again, only for a CUT at the moment.
Enjoy,
Taylor
   / New iMatch AutoHitch #10
Really ? , that cool. i guess thay did come out with it after all. :)
but the real fact is after someone here gets one..;)
PS... What is RFDTV.....:confused:
Chris....:)
   / New iMatch AutoHitch #11
Does any1 know if the 2520 is compatible??
   / New iMatch AutoHitch #12
Chris....:)
My opoligies to everyone. I was completely wrong..:(
after looking at this closely. this was not what i was talking about.
this is a completely different tool . what i thought this was . is the single lever IMatch quick hitch. JD acualy had it on there website and the attachment book. but my dealer said it just never came to pass.
and you could not order one. it was not this PTO shaft connector.
so i was wrong....:(
Chris...:)
   / New iMatch AutoHitch #13
I have seen the auto hitch listed on the on-line catalog for the 2520.
   / New iMatch AutoHitch #14
Does any1 known how it works exactly?
   / New iMatch AutoHitch #16
Amazing, I want one!
   / New iMatch AutoHitch #17
That a real slick setup!! Definitely something to consider should anyone be lookin' to upgrade a newer tractor or when buyin' a new CUT.
And RFDTV is a great channel!! If you have a chance to get that on your cable or satellite -- it's worth it.
AKfish
   / New iMatch AutoHitch #18
Hi all,
I was looking at that autohitch and went on the site to find it like $380.00 for the autohitch and another $270.00 RC1070 rotory cutter Attachment so you can hook it up I think i will just get off the tractor and put on t the PTO myself.
Matthew3120
   / New iMatch AutoHitch #19
a must have for anyone changing implements often. for me, my backhoe is on most of the time so not worth it.
   / New iMatch AutoHitch #20
Hear, hear. I wish I could leave the 3PH draft arms in place with the backhoe on. Hooking up or removing the backhoe has been a matter of 2-3 minutes. I've got the 3ph assembly down to about 10. For the bolted keepers on the main pins, can a lynch pin be substituted for the nut and bolt? Still, for me this assembly takes all the time and an I-match would just add an extra step. I haven't had a problem jostling implements into place, even on sloped ground. It is significantly easier with a helper to line things up while I lift, backup etc.
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
