New Jd 2320 cooling line looks rusty
   / New Jd 2320 cooling line looks rusty #11
No, I think water got on the battery enough to cause a circuit between positive and negative causing the battery to possibly overheat or whatever a battery would do in that case and leak out or "explode"
No, that's not gonna happen.
   / New Jd 2320 cooling line looks rusty #12
AGREED! and even IF it did, there is a tube attached to the battery that routes any overflow overboard and away from the area.
Well I got my baby back today. Pullin her home now. Not reeeeeal impressed with the repair but we'll see how it holds up. They replaced the battery and painted the damaged cooling line and plate that the battery sits on. I was thinking they should've replaced those parts to new again. The paint looks kinda half a**.
   / New Jd 2320 cooling line looks rusty #14
AmericanJD is your 2320 new? I am waiting for a new 2520. Reading old posts I thought that the battery leaking issues had been resolved?
I hate battery corrosion on any vehicle and dread the thought of a new JD tractor possibly having that issue.
I was hoping by now for a sealed battery and no leaks.
Tried to remember to check so many things when buying a new tractor it never occured to me to check the battery.
P.S. I am E-mailing the dealer ato ask.
Yes, I bought it from the dealer a little over a month ago maybe two now.
   / New Jd 2320 cooling line looks rusty #16
I would not accept that repair on a new machine. Demand to speak with a regional rep. It should be fixed "as new" under warranty-spray paint is not as-new.
Thank you kenny. A second opinion really puts it in perspective. In the back of my head I'm thinking it is just a tractor but at the same time it is BRAND NEW. And I've never bought anything new before. I could've done a better repair than they did. They put something in front of the radiator and sprayed the cooling line which didn't even get it all on the back side. Anyways, I appreciate it!
   / New Jd 2320 cooling line looks rusty #18
yup..i agree. needs to be replaced. not repainted. Also, feel free to wash the battery all you want. it WILL NOT short a battery. i wash mine all the time. Actually that helps keep corrosion down, and keeps everything looking great.
If metal is corroded by battery acid, paint will just cover it up, its still rusting underneath. Man, the dang batteries are a real pain in the a%%. I had to replace both battery hold down brackets, bottom plates and screws on the 94 dodge.....$180.00 later, they look brand new. Probibly more than the trucks worth hehe.
Hahaha
Ok, they said the reason they did not replace the parts is that if they pressure tested the line and results were good then warranty declined the idea of replacing the parts. I told them that doesn't satisfy me and about the rust under the paint. They called me at 8:15 this morning and are ordering all new parts. Supposedly warranty dept. Will not cover new parts so the dealer is taking the hit. I don't believe that but hey, I'm getting what I want! Thanks guys for inspiring me to call.
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
16ft T/A Flatbed Trailer (A52377)
16ft T/A Flatbed...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A52377)
2019 Chevrolet...
