New L5740 show and tell
   / New L5740 show and tell #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Hi, After some debateing here and at home with Kubotas 0% / 5years I decided to go for it. I traded my L5030 loader and woods 9000 hoe with 1955 hrs on it on a new L5740 and loader. I really need the spliter in the tranny. I am done removing trees here so I should be good there.
Set up skid steer QT on bucket,3 rear remotes with float, defost side and rear window, rear wiper, work lights and a nice am/fm/wb/cd radio.
The only down side is I have payments for 5 years now.
   / New L5740 show and tell #2
Very nice tractor, I will probably trade my L5030 in on one of those some day; still love my L5030 though.
   / New L5740 show and tell #3
Congrats on the new tractor. I wish I had a use for a L5740.
   / New L5740 show and tell #4
I see from the picture you traded at Ravenscraft.I like doing busines there have
been treated fair. Nice tractor.
   / New L5740 show and tell #5
That thing is goegeous....
When you look up tractor in the dictionary there should a picture of that tractor.!!:thumbsup:
I think you're gonna love that tractor.....
Ravenscraft is the best to deal with, I have bought a few items from them over the years. There a small company, honest (for a dealer) and they stand behind what they say. The service dept is all ways willing to answer questions as well.
I am going to miss hoeing around, but this is a sweety except for the seat (foam is too hard for me). I orded a new air ride Grammer for it. should get it soon.
   / New L5740 show and tell #7
What model seat will fit the L5740 and about what is the cost?
   / New L5740 show and tell #8
Beautiful tractor. This time of year I would love a cab! Is it quiet in there?
OK all, I got my front chain hooks on for chaining down to trailer the 3/4 bolts are not tight so I get up/down movement.
Also got my grapple/post hole digger hyd lines plumbed aswell.
Still working on front blade. I got it installed but the lift does not go high enough to get it oon my trailer so I am going to add a 8" cylinder and remove there 6" stoke. This should be an easy fix. It will be a nice addition the haul it with the front blade.
After this is done I will then work on the seat swap, and yes all the parts are here.
   / New L5740 show and tell #13
Any pics with it all loaded up on the trailer, wouldn't mind one or two of the tow vehicle also.
Thanks
Will
I replaced the lift cylinder of the front blade with a 2 x 8. Now she getshigh enough to load on the trailer.
wmonroe, Here some pics for you.
DDT
   / New L5740 show and tell #15
You mentioned installing lines for the grapple and PHD, are the hydralics enough to power a motor for the PHD?
Nice looking rig. I like the hooks on the brush guard for trailering.
I run a set of hoses from the 3rd SCV on the rear to just under the loader couplers for front mount hyd, this way the re plenty of flow for the PHD. Dealer told me the joystick 3rd control valve would not have enough flow for PHD.
Yes the front hooks are for holding her to the trailer, there just loose enough to swing up/down for automatic adjustment.
Thanks
DDT
   / New L5740 show and tell #17
I like small drives run off the remote for post hole diggers. You can mount them off the front boom you just need the hoses. We have a lot of stones...
I think you could let a couple of lbs of air out the the back and get more traction and a better ride. Get the full bar touching the ground.
   / New L5740 show and tell #18
DDT,
I was looking at your pics and just noticed that you mounted your brush guard over your mount for the subframe. Every six months I was taking off the brushguard and installing the mount for the subframe. Thanks for the heads up. I will just leave it attached under the brush guard.
   / New L5740 show and tell #19
Enjoy...It will be interesting to hear what the extra horsepower does for you. I've been real happy with my 5740 (minus cab). I still can't get over the strength of the hydraulics on such a small machine. The price of the Super UDT fluid wrankles my shorts a bit but the few times I've had it out in the cold I haven't noticed any problems with the HST.
You seen right, but I had to cut the front bottom bar out of the grill guard to allow room for the front blade. I got longer bolts for the grill guard and for the mid brackets that attach to loader bottom so there is enough threads to hold.
I did the same to the last tractor and had no problems.
I was useing my DB-6 sraper yesterday. WOW the extra HP with the splitter tranny is asume.
And yes I got my grammer air ride seat installed to, How sweet it is,how sweet it is.
Jaw Crusher (A59228)
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2455 (A60432)
2455 (A60432)
2023 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
