Wild Bill the 2nd
Greetings,
Got my new L6060 a couple weeks ago. I've had it in the garage a couple of times. Once to put fittings on the 3rd function and then a couple times getting the aux lighting mounted and wired.
After I installed the fittings for the grapple it stayed in the garage overnight. I left the grapple open to surprise my wife the next morning with that mean I want to eat you for breakfast look. But the next morning one of the lids had drooped closed. When I backed the tractor out I noticed a small puddle of hydraulic fluid on the floor. I thought a fitting or valve for the 3rd function was the culprit. I went and looked but found nothing.
Last night I finished wiring in my lights and as I was working I saw a puddle forming and growing. When I looked around under there the only thing I found was oil on the pin from the weep hole in the bell housing. After 5 hours the puddle was like 8 wide and 12 long. A decent amount for a tractor with 7 hours on it.
I called my dealer and they will get it in there as soon as I say the word. I just need to get a couple things done since I had been without a tractor for a month while I waited for it to come in.
So, has anyone else seen this? Could it be anything but a seal inside the trany? I imagine that the tractor will need to be split before it is 10 hours old. Sad
At least the lights turned out good.
