There are so many totally stupid ideas floating around about home brew or commercial snake oil additives to diesel fuel that it is comical. If the maker says don't do it, DON'T DO IT no matter what someone with grease under their fingernails says.
Put a little gasoline, add some kerosene, add some alcohol, add some ATF add some freaking pixie dust if you want but it isn't a good idea. Too bad that CarFax can't report the use of weird additives or the IQ of the previous owner.
Anyone know where I can get a good used Marvel Mystery Oil inverse vacuum oil dispenser?
There are usually additives approved by the maker. It is safer to stick to those. Cummins approves some additives. Ford approves an anti gel agent and a cetane booster. Ford prohibits using over 5% biodiesel (2008 F-250 manual.)
It is very humorous to see what they think they have to tell a new owner. They explicitly warn against adding used crankcase oil to the diesel fuel. Would they do that if there were not a significant number of idiots out there doing it?
Here is one for the true believer whose mind is made up and doesn't want to be confused by the facts...
When your child looses a deciduous (baby) tooth take the tooth before giving it to the tooth fairy and soak it in an imperial (not American) quart of diesel fuel overnight (didn't say anything about a full moon but it couldn't hurt) then use that "enhanced" fuel as a diesel fuel conditioner. For extra power do the soaking under a pyramid made of Q@#$ %@!$#.
If you don't pass this tip on to at least 10 diesel owners within 10 hours your injectors will clog!
Pat
