New member kubota b7200
   / New member kubota b7200 #1
Mcfclz
Bristol ct
Kubotab7100
Can I use on board hydraulics to power FEL and back hole
   / New member kubota b7200 #2
A loader should be no problem...something like a model LA 301 or smaller etc...
You will have a hard time finding the only BH recommended for a b7200 at a reasonable price...which is model # B4672A...this BH is not listed on the link but it is on other sources...
TractorData.com Kubota B7200 tractor attachments information
Good luck...
   / New member kubota b7200 #4
:welcome:
To the forum from Alabama.
   / New member kubota b7200 #5
Yes you can use on board hydraulics for those. Keep in mind your tractor does not have power steering so it can be difficult with a loader with a heavy load, but manageable.
Also you would be wise to fab up a sub frame to take the added forces and strengthen the connection between front and rear frame. Dont rely on the transmission bell housing.
I had a B6200 Hsd which is the next smaller unit than yours. I purchased plans for loader and backhoe from PF Engineering but did not build either. Instead I decided to trade up to a B2620.
Thanks for your info! Very helpful Thanks Guys
   / New member kubota b7200 #7
This tractor is even smaller. And yes I did have to reweld the tranny bell housing. Now its well supported. I used it for 8-10 years now. bucket is only 3 ft wide but it will lift 400 lbs.
Photo looks great how did you connect your hydraulics! Thanks
I have a belt driven hydraulic pump on a case 442 FEL,when ever I engage the value the pump squeals & motor bogs down to almost a stall. What can I do to correct this issue!! Your thoughts thanks
   / New member kubota b7200 #10
Hello there and welcome to TractorByNet! I have moved your thread to the Kubota forum where you can speak with other owners, such as yourself. Best of luck! :thumbsup:
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
New Holland C185 (A47477)
New Holland C185...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2016 FREIGHTLINER...
Self Dumping Hopper (A53316)
Self Dumping...
