New member kubota b7200
   / New member kubota b7200 #1
Mcfclz
Bristol ct
Kubotab7100
Can I use on board hydraulics to power FEL and back hole
   / New member kubota b7200 #2
A loader should be no problem...something like a model LA 301 or smaller etc...
You will have a hard time finding the only BH recommended for a b7200 at a reasonable price...which is model # B4672A...this BH is not listed on the link but it is on other sources...
TractorData.com Kubota B7200 tractor attachments information
Good luck...
   / New member kubota b7200 #4
:welcome:
To the forum from Alabama.
   / New member kubota b7200 #5
Yes you can use on board hydraulics for those. Keep in mind your tractor does not have power steering so it can be difficult with a loader with a heavy load, but manageable.
Also you would be wise to fab up a sub frame to take the added forces and strengthen the connection between front and rear frame. Dont rely on the transmission bell housing.
I had a B6200 Hsd which is the next smaller unit than yours. I purchased plans for loader and backhoe from PF Engineering but did not build either. Instead I decided to trade up to a B2620.
Thanks for your info! Very helpful Thanks Guys
   / New member kubota b7200 #7
This tractor is even smaller. And yes I did have to reweld the tranny bell housing. Now its well supported. I used it for 8-10 years now. bucket is only 3 ft wide but it will lift 400 lbs.
Photo looks great how did you connect your hydraulics! Thanks
I have a belt driven hydraulic pump on a case 442 FEL,when ever I engage the value the pump squeals & motor bogs down to almost a stall. What can I do to correct this issue!! Your thoughts thanks
   / New member kubota b7200 #10
Hello there and welcome to TractorByNet! I have moved your thread to the Kubota forum where you can speak with other owners, such as yourself. Best of luck! :thumbsup:
2017 CHEVROLET SONIC (A55745)
2017 CHEVROLET...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2003 Mercedes Benz CLK 350 (A53314)
2003 Mercedes Benz...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
