mllud
- Joined
- Oct 4, 2019
- Messages
- 310
- Location
- Missourian
- Tractor
- Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
Some engines have a decompression lever .I'm thinking that's what Agvg meant. It changes cam timing enough to help spin the engine easier on startup, On a motorcycle it prevents kickback.
A pull start may help if your in a situation to do safely do that. Pull start gives longer and higher engine rotation to get fuel flowing and build some heat and compression.
When you bled the fuel I think you need more than a tiny bit at the injector. Could need more bleeding. The injector should spray a good spurt/mist.
