New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas?
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #11
I suspect an abandoned well that was once filled with dirt which has now settled.
Bruce
Bruce
Hello gentlemen. I am leaning toward the well idea. That makes a lot of sense. I am thinking of building a sturdy steel framed plug or cap to cover it as a temporary solution.
We are thinking of converting that part of the front pasture to forest land as we live on a busy road and having trees there might reduce traffic noise and give me some peace in my old age! :)
Look at the video. Sure looks like a steel casing sticking a little above grade. Ron
I did not see any steel...the steel you probably saw was the top of my hoe, was using the handle as a probe.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #14
I have a new to me pasture in front of the house that slopes down to the road. It is about 3 acres. I was walking around inspecting it and found a very deep hole filled with water. The hole was about 10" diameter but very, very deep. I have never seen anything like it. I did not want to push to hard with my hoe handle fearing of breaking a pipe or something. I know the county rural water goes up to the house, so I will contact them about it. I can't tell if water is from a pipe or from filling by the heavy rains...
Any thoughts?
Skinny deep hole - YouTube
When you were probing it with that hoe did you tap the sides to see if they were cement, metal or dirt?
I think it was just dirt!? I don't remember any cement or metal...but I will check again tomorrow...
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #16
....Mexican drug smuggling tunnel.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #17
It screams field tile stealing dirt to me. You get a field tile, a lot of older ones were clay, they get a bad joint, and as water flows through it the dirt gets sucked away. You can dig down and repair it or just fill it in. A tile probe would let you know for sure.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #18
Bought my house 20 years ago. The septic tank leach field had plastic tubes sticking up out of the ground; nobody could tell me why. In addition, the drainage from my leach field extends about 200’ from the field itself.
So.....a remote possibility is that it has something to do with a leach field (assuming you’re on a septic system).
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #19
Slowly dig around outside maybe there stone or boards for walls.
   / New to me house with 3 acre pasture in front...found a deep, deep skinny hole! Ideas? #20
Before messing around it much I would heed another poster's suggestion that you tie off to something for safety. Some of the old dug wells went pretty deep into the ground, widening as they went. After a while the sides get unstable and can collapse.
16ft Enclosed Trailer (A57453)
16ft Enclosed...
2 POLY PIPE (A58216)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
2015 Vermeer VX30-500 Gallon Tandem Axle Vacuum Excavation Unit (A59213)
2015 Vermeer...
UNUSED Wheeled Dump Hopper (A55272)
UNUSED Wheeled...
