New to me Tilt deck trailer advice?
   / New to me Tilt deck trailer advice? #21
$160 a tire to replace what I got http://www.tirerack.com/tires/TireSearchResults.jsp?width=8.75&ratio=0&diameter=16.5 or $175ish for a new E range tire on a new 8 lug rim http://www.easternmarine.com/12-thru-16-Trailer-Tire-Rim-RADIAL/ I expect they don't promote D range tires on 8 lug rims. I'll probably go with the new rims suggestion when it comes to that, only a hair more. Will think about downgrading to a D range for the better ride at my load capacities. Looks like I might have to downgrade my great deal to just a good deal.
Fallon;
Easy to spend someone else's money but, I would stay with LR E tires. Why limit your trailer for unknown future needs just to save a few $$? Your best economy will be switching to 16" wheels and E tires. Don't think you would be able to tell the difference on "ride" between 'D' and 'E' tires. The extra load safety factor is worth the small incremental cost.
You still got a great deal as you will get 6-7 years out of tires regardless of how many miles you put on trailer. You were going to put new tires on it at some point as it would be foolish for seller to put new tires on it for an auction. Now your tires won't be a worry. We have a 24' GN trailer with LR E tires that was purchased new in 2007. It gets used 4-5 times a years so tires had, at most 1000 miles of use. Last fall blew out 3 of 4 tires on 3 short trips with way less than max load hauling B2710 Kubota with FEL and MMM. Changing tires on the side of the road is a big PIA. After 3rd tire I gave up and replaced all, including spare with new.
My 2cents worth. Good luck!
   / New to me Tilt deck trailer advice? #22
Get rid of the 16.5 tires. Like others mentioned get LRE tires and 16" wheels. Saving a $100 now makes no sense if you were to get a new truck or have to borrow a bigger truck to haul something heavier.
Chris
Ya, I was already intending to go that route. More standardized & the current rims are a bit rusty.
Probably pick up a spare on a 16 this week then swap out the rest eventually.
My hauls in the near future are under 25 minutes on slow quieter back country roads. I can gamble on having to swap a tire on the side of the road. A slightly mismatched tire will limp me home until I could swap out the remaining tires.
   / New to me Tilt deck trailer advice? #24
Ya, I was already intending to go that route. More standardized & the current rims are a bit rusty. Probably pick up a spare on a 16 this week then swap out the rest eventually. My hauls in the near future are under 25 minutes on slow quieter back country roads. I can gamble on having to swap a tire on the side of the road. A slightly mismatched tire will limp me home until I could swap out the remaining tires.
Don't forget with a 16 inch rim that bolts onto your trailer you could mount a used LT pickup truck tire of the same height as your other tires! LT tires run great on trailers. This is an option for now as you talked about getting 4 new tires, in the mean while a used truck tire would be better than nothing at all
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
19088 (A55758)
19088 (A55758)
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
